Torque specs
rocket67
Hey wondering who may know the proper torque specs. About to lift my TE 4runner.
Lower shock bolt
UCA to Frame ( long bolt )
UCA to spindle
KDSS Sway bar to LCA
LCA to frame
also being KDSS TE. If I disconnect the sway bar from the LCA's while truck is sitting on wheels will the KDSS piston extend and cause damage or should I strap it before removing the bolts?
Lower shock bolt
UCA to spindle
LCA to frame
Nashman posted the entire repair manual that includes all torque settings here: Free Cloud Storage - MediaFire
The KDSS piston will extend. It will not damage anything but you'll need to compress it again in order to get the sway bar brackets to align with the LCA again. I usually put a jack under the piston to keep it from expanding.
I tried to download these files but there is an error.
"The file you attempted to download is an archive that is damaged or possibly encrypted. MediaFire does not support unlimited downloads of broken or encrypted archives and the limit for this file has been reached. This file may only be distributed from a premium account."
I would love to be able to download the repair manuals for my truck.
Thanks,
- Tim
Thanks,
- Tim
I just tried the links supplied by Jaker... they are working. Download all 3 first and then unzip them
This might help...
