Total Chaos 2" Long Travel Kit - 5th Gen 4Runner
2010+ 4RUNNER 2WD & 4WD
TOYOTA 4RUNNER +2" LONG TRAVEL SUSPENSION
  • 2" extended 4130 chromoly tubular upper arms bolt to factory control arm mounting locations.
  • Upper and lower ball joints are replaced with 1" uniballs for maximum wheel travel and component strength.
  • TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
  • Boxed and internally gusseted 2" extended lower control arms bolt to factory control arm mounting locations and are pre tabbed for dual shock capability.
  • 2.5" long travel specific coil over shocks bolt into the factory coil bucket location. Extended travel shocks are too short and will not work.
  • A secondary external bypass shock can be installed to increase dampening and tune-ability.
  • Bolt on lower uniball adapters are CNC machined from billet steel and include shortened factory hardware for ease of installation.
  • Lower control arm is compatible with Light Racing Jounce dome pad if vehicle is already equipped with this model bump stop. 1 1/2" extension for Jounce shock is sold separately.
  • Spring rate options offer the ability to customize your ride for your specific application allowing you to custom tune the vehicle for specific terrain or desired performance.
  • Adjustable limit strap clevis' are included so that you can properly limit the suspensions droop wheel travel and make necessary adjustments during the life of the limit strap.
  • Stainless steel DOT braided brake lines, TC custom 17-4 stainless hi-misalignment spacers and all grade 8 mounting hardware is included.
  • TC 4340 custom extended axles reuse factory inner and outer CV's to retain 4wd.
  • (axles are sold separately and not included with the kit)
  • 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
  • Hand crafted in the U.S.A.
  • Fiberglass fenders not required on FJ Cruisers. 4Runners are limited to 275/70R17 tires unless fiberglass is installed. Fiberglass fenders or extreme fender modifications/cutting required on Tacoma.
2" Standard Kit
Part #86002-10FJ (Bushing Pivot UCA's)
Part #86002-H-10FJ (Heim Joint Pivot UCA's)
- 100% chromoly constructed Race System offers maximum ground clearance and weighs16.8 pounds less than the standard TC +2" LT kit.
2" Race Series Kit
Part #86002-R-10FJ (Bushing Pivot UCA's)
Part #86002-R-H-10FJ (Heim Pivot UCA's)
For a Complete List of Kits - With and Without KING Shocks - Click Here
_
