TOTAL CHAOS Weld-On Rear Bump Stop Mount (KING)
PART# - 48624K
PRICE - $249.99
  • Increase rear suspension dampening control and reduce harsh bottom outs with added weight packed in the rear of the SUV.
  • CNC laser cut brackets weld to the outer frame rail and offer easy access to adjust the nitrogen pressure.
  • Designed to work with KING 2.0" compact threaded adjustable bump stops and adjuster nuts.
  • KING bump stops offer adjustable nitrogen pressure to custom tune your vehicle for your specific use and off-road application.
  • Cutting, welding, and basic fabrication are required.
  • Designed to reduce rear-end "bucking" sensation and the harsh bottom out with factory rubber bump stops.
  • No need to remove the rear coil spring to adjust nitrogen settings like other brands.
  • NOT INCLUDED in kit: QTY (2) KING PT#BS2120
Installation Instructions
Want to order a Rear Bump Stop Kit?
Please email [email protected], call 951-737-9682, or visit one of our Authorized Dealers
TOTAL CHAOS
WWW.CHAOSFAB.COM
Jhunt
