Total Speaker Replace
aeathb
Hello, I am thinking its about time to replace all of the speakers in my 2008 SR5 with the 10 speaker JBL Synthesis. For those of you who have already done this, what is the best way to get all new speakers, (tweeters, sub, everything) without spending a fortune? I looked at the stock speaker replacement option and I'm pretty sure it would be cheaper to buy a new 4runner at their price. Thanks!!
Amazon.com. In my opinion, Kenwoods are the best value. I have Alpine Type S speakers and Kenwood speakers and like the Kenwood's better. They're typically cheaper. Alpine Type R's should be amp'd which would be another 200$ or so for that, so stick with Kenwood's. Get components because you can mount the tweeter wherever you want. Amazon has everything much cheaper than BestBuy and Crutchfield. Crutchfield is nice because they give you brackets, which makes installation much easier. But you can usually find those in other places on the internet.
So to answer your question, in my opinion it is best to order Kenwood speakers from Amazon, and buy mounting brackets from some other online store and install everything yourself, it's really easy and will save you alot of money.
Now you need a Head Unit. They do allow you to crank it up louder and the sound is much clearer than the stock one. If you need help regarding HU's let us know whether you want a touchscreen style ( Double Din ), or a basic stereo. (single). I'd get it from Amazon once again, but check Crutchfield first because that will tell you whether it's 4Runner compatible. But I wouldn't buy it from Crutchfield, just get the mounting bracket and wiring harness from them.
Prices would be:
80-600$ for head unit depending on features and brand
30$ for mounting bracket
5$ for wiring harness
Subs- Anything non- Sony will sound great. Just buy the best you can for your budget. Read reviews off Crutchfield. Don't go by the peak power rating. Go by the RMS, that is how much continuous power is going to them. Peak would be one huge blast of bass, which is important, but RMS is by far the more important statistic.
Amp- Just get an amp that can power the RMS of the subs. Alpine and RF are some of the best amps but very pricey. You are probably better off with a cheaper brand, but don't go so cheap that you are buying an unreliable product, for example, Lanzar. Their stat's are over-exaggerated. Get a wiring kit from Amazon. As far as I know, they're all the same.
As you can see, it's hard not to spend a fortune on car audio. It's one of the biggest scams there is in my opinion because they are marked up beyond belief.. It's up there with razor blades, movie popcorn, soda, Advil, whey protein, and professional sports jerseys. So be prepared to spend a lot of dough.
swisscheeze29, thanks for your explanation!! This helped a ton, and to think I was even considering dropping tons of money on the cheap stock speakers. As far as head units, what would you recommend? For head units I would realistically be looking at the non touch screen; touch sceen would be cool, but way more expensive. Thanks again!!
For the standard Head Units, referred to as "single DIN" you want either Pioneer, Alpine or Kenwood. I'm sure some other will work fine, but those are the big 3. Look for one that has 50x4 power. Thats the most powerful they will come. Some are 45x4, but those are weaker. Also, research what features they have. Some features to look at are:
- Plays music off a flashdrive
- Has a remote for when you're turning it on and you're not in the drivers seat. Good for football tailgates and stuff when everyone's gathered around the car
-Ipod connectability
- How user friendly is it?
And with all brands, they have super cheap models, and very high quality ones. So read plenty of reviews before buying. Brand isn't everything.
You should definitely get a new head unit. You will be amazed at the difference it will make. Do you have the JBL system? If so It will take some work to make all ten speakers work. You will have to splice the cargo speakers into the rear speakers. They may make a wire harness adapter for this not sure. Good luck
He raises a good point. When you are about to do it, get in contact with someone that has the JBL and ask them what other things you need to know. I don't have it, otherwise I would lead you through it.
