Cederbaum said:How do u guys feel about chains... for pulling someone out or getting pulled out when stuck... cause thats what i am using now?
Ohio4R said:Dont use chains you might break a window
Ulfr said:I don't mean to be rude, but have you guys seen elastic ropes/straps rip apart?
Bear in mind tho' things can go pretty out of control within a second.
boston_kevin said:I have seen these snap before, usually when trying to use a strap that is underrated for the task. Keep in mind that all straps say you should throw a blanket over the strap to prevent damage. I have had tow ropes break, but never a snatch strap, but then again, I use 20,000 lb rated snatch straps for a 6000 lb truck.
