Towed a bit more boat today than usual
GTOchris
I normally use my 4Runner to tow my 20ft boat for gas/ storage- all local a few times a year when not in it's slip, it's right at 4,500 lbs on the trailer which is single axle with disc brakes- I've yet to break 50MPH towing with it however it does the job for local runs and would not do any distance moves. I've been towing all my life so it's nothing new.
Friend of ours Tahoe broke down the same week his boat broke down so no marina can pick it up for 2 weeks so we used the 4Runner. I didn't realize how heavy I bit off... Now that I looked it up it was every bit of 6,500lbs. Tongue weight was relatively light, rear didn't drop more than an inch.
We only went 7 miles with it on local roads- never got over 40MPH with some rolling hills. I was VERY gentle on the transmission / throttle and just tried to use momentum as much as possible and let it fall into whatever speed it preferred.
Was this a really bad on the drivetrain for a one time tow? It felt remarkably un-eventful, rather stable, good braking by the truck/ trailer just short on power. My temp gauge never moved and I left the engine idling a bit while un-hitching just to ensure the trans fluid could cycle/ cool rather shutting off. I changed the trans fluid last year- should I be concerned?
Nah, that type of towing won't stress anything much at all. I doubt things even got up to their steady state temperature with that short of a tow.
No worries, sounds like it didn't flinch at all.
V6 is rated to tow 5k and the V8 is rated for 7k. Same parts, different motor. The V8 has more torque thus the higher rating. Don't sweat it, I tow around a 5800 lb enclosed trailer almost every day and it has yet to flinch. I don't go as easy as it sounds you were either. ;)
Thanks- I think I can sleep better now.
This experience sold me on the stability of a tandem axle trailer, completely different experience for the better however the lack of HP was the issue. I was mostly concerned about my transmission and engine since my truck is stock (no extra cooling).
H.Sikina
