Towing Help
96Blacklimited
I am planning on towing a 95limited with My 96 Limited. I am using a vehicle transport but not sure about the weights. The door sticker on my 96 limited says (GVWR is 5250lbs) and i think the 95 4runner weighs in around 4200lbs. I figure with the runner+tailor=6500lbs. i just wanna know if its safe to transport 25miles?
leave it in 2wd
x2 plus you need to make sure the OVER DRIVE is off, you do this by pressing the button on the side of the shifter(in case you didnt know) The short distance at an easy pace and allowing plenty of stopping room you should be fine. Try to do it at a time of little or no traffic and think ahead for stops and turns.
