TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
Just downloaded it right now so it's still working. You just have to triple check the URL and capitalization matters.
Is sharing turned back off again? Getting a Google drive page that says: “Sorry, the file you have requested does not exist. Make sure that you have the correct URL and the file exists.”
triple check its typed correctly, it still works fine
Manually checked for accuracy and caps. Also saved pic and let my iPhone read it automatically with OCR. No dice.
EDIT: Found the issue was in my Notes app where I was copying and pasting, there is separation between pasted text (despite already reading like a hyperlink) and the actual underlying hyperlink.
So when I made my last edit (iPhones OCR fudged a capital W as lowercase) I made the change manually to the text, fixed the W, then long pressed, copy URL, Safari, takes me to Google Drive, but “file does not exist”.
Turns out the manual edit was only to the text, not the link itself. The link (invisible URL) still had the lowercase W.
Got what I needed now!
Another satisfied customer...
... saying thank you. :biggrin2:
I checked Haynes' website; still no book for my 2017 4runner (digital or print). According to the reasons listed in the FAQ, either this model is still new new or there are too few vehicles produced... :noidea:
Being that the 4Runner hasn't significantly changed since 2009 and has had more than 1.16 million sales since then..... not sure what Haynes' minimum requirements are.
Oh well, if there's nothing I can do about it, I just won't bother with Haynes.
:hand:
I'm getting a file does not exist error. Anyone else?
Also. 7Zip does NOT want to play nice on a Mac.
I scrolled through the comments of this post and found these comments:
lancan: "... Also for anyone using Mac I was able to unzip using StuffIt Expander (free) pulled from the App Store."
codeman870: "Awesome! Also, Unarchiver for OSX will work!"
Gamma Ray: "I'm not a Mac user, but look at the bottom of the 7 Zip download page. It has a link to Keka for Mac. https://www.7-zip.org/download.html"
I hope this helps!
Hi DougEFresh2, I have tried to get the google docs file, typed in the link from the photo, verified it three time, but the link comes up with the file missing.
Is it still up? thank you
Ah, found the issue.. the original post has
"file/d/"
in the url. That does not work anymore, not for me.
But replacing it with
"u/0/uc?id="
this worked. THanks!
youngrk
