TOYOTA 2016-2019 4Runner Repair Manual RM27F0U
I'm not going to pretend like I know all of the differences, or even all of the differences within my own guide of all of the 5th gen 4Runners.
However, I do know of two.
The first is the addition of the emission control valves that sit on top of the engine block that were introduced in 2013.
The second is all of the driveline changes that I compiled into a spreadsheet and saved as an image near the bottom of both of my posts.
Basically, with the exception of the addition of the emission control valves, I THINK this guide will work for all 5th gen 4Runners. Now, the reason I don't directly come out and say that in any of my posts is because I don't want someone with a 5th gen from a different year to find out the hard way that I made a wrong assumption. And as a result, they accidently ruined a part of their 4Runner from directly following my guide.
To find out (for sure) that every single part number and torque specification is the same for every single nut and bolt in all 12 years of the 5th gen 4Runner would cost even more money and a significant amount of additional hours to confirm.
Sorry for the long winded answer. Chances are, this guide will serve any 5th gen 4Runner owner just fine. But worst case scenario, this guide can still be used as a starting point to at least know what to research and look for.
:grouphug:
Just download as well for the brake job front/back, and fluid changes. Mainly got it for the torque specs.
Thanks for the work in putting this together.
This is amazing, good work!
Are you able to share any tips or tricks for anyone thinking about creating their own?
Did you go to each page, save to pdf, then combine them and create the TOC?
Or did you find a way to automate it?
To merge all of the individual PDF files into one big PDF file:
PDFsam Basic - PDF Split and Merge Basic Edition (version 4.1.2)
Split and merge PDF files. Free and open source - PDFsam
To create PDF Bookmarks:
JPdfBookmarks (version 2.5.2)
JPdfBookmarks download | SourceForge.net
To remove all unwanted hyperlinks:
Adobe Acrobat 11 Pro
* Download older versions of Adobe apps
You can download it from here if you already bought an older version but lost the original install file.
If you don't already have Adobe Acrobat, you can get the Standalone version or DC (monthly subscription) here:
* Adobe products: desktop, web, and mobile applications | Adobe
If you only plan on using it one time and want to save money, I would buy "Acrobat Standard DC" for just one month.
Under "Acrobat Standard DC", click "Buy now", "Monthly" and then fill in your payment method and buy it.
I would NOT choose the "Yearly Billed Monthly" subscription!
Even though it appears to be cheaper, there is likely an early termination fee that would cost you more money than the difference between the "Monthly" subscription amount and the amount you would pay monthly for the "Yearly" subscription.
- Be aware that even the "Monthly" subscription states "Cancel anytime, no fee", which means that you'll keep getting charged every month until you cancel it.
On the other hand, if you don't want to continuously pay a subscription and don't care about the latest features, then you can choose to buy a "Standalone" version:
Acrobat Standard 2020: $299
Acrobat Pro 2020: $449
Adobe Acrobate Feature Comparison:
* Compare Adobe Acrobat versions DC, XI and 2017 | Adobe Acrobat DC
We got one for 2021? :)
So, according to
"https://www.toyota.com/4runner/"
and
"https://www.toyota.com/4runner/2021/",
it looks like the pattern of the shift nob gating looks identical to my 2016 SR5 and the location and looks of the electronic dial of the transfer case also look identical. I would bet that both the 2021 and 2022 are mechanically identical to the 2020 models just based off those findings.
At the time of making this guide, the 2021 stuff wasn't available, so that's the only reason I didn't include it.
For anyone that wants to grab the baton and continue what myself and many others have done, that would be awesome!
The biggest motivation I had to make this guide in the first place was the fact that I actually own a 2016 4Runner. I'll gladly give advice on where to go and what tools to use, but unless I sell my 2016 for a newer one, I don't think I'll be doing this again, at least for a while.
Side note, if you want to find out for 100% sure what mechanical components are optioned in any Toyota, you can go here:
https://techinfo.toyota.com/
then under "First Time User and Need a New Account?" click "Subscribe", pay the $20 (or whatever the going rate is) and look under the "Manual" section, and find your vehicle.
Hope this helps! :cool:
idk what im doing wrong but i cant get it to open
you have to type in the web address at the bottom of the last picture. capitalization matters for that also. you don't need to type in the http part
then when it asks for the password, just copy and paste this password (from x->3).. x*x*x*_Do_NOT_Post_This_Link!!!_7ha6S1I6Cs83
Password doesn't work
So the file downloaded with 7z that I installed as well, however, every time I enter the password, x*x*x*_Do_NOT_Post_This_Link!!!_7ha6S1I6Cs83, it says wrong password. Did the password change?
youngrk
