DustyRoads
I'm getting ready to do the head gaskets on my 96 elocked 5speed.
Misfire in cyl 3 after losing a coolant hose and mild temp gauge top out when parked and left running for a minute. Eek! Parked it and had it towed. I'm prepared for a new head if needed but I hope it doesn't come to that. Sigh.... i love this truck.
So far i'm assembling an OEM parts "kit" and placing the parts numbers here. Toyota doesn't offer a complete kit like amazon and ebay sellers.
Using Haynes, maybe a Chilton and this most excellent video series as the reference material. https://www.youtube.com/watch?v=voLBRDZL9fE
Please let me know if I'm missing anything crucial in the rebuild. I did everything from the valve cover gaskets upwards as of last fall. Hoping to only redo the valve cover gaskets and spark plug tube seals when i'm in there again. If i need all fresh seals and parts let me know. I want this thing to LAST awhile.
Thanks for any input and hopefully this can become a usable parts list for those doing the job in the future. I hadn't seen an OEM "kit" list around yet. I'll edit any additional info into the original post.
Here is what i have so far from the Camelback Parts (parts.camelbacktoyota.com) Is there a better source and/or prices anywhere that ya'll suggest for this stuff? I guess Toyota of Dallas (www.toyotaofdallas.com) is a good one also.
Special thanks to those contributing members and Toyota techs that helped out with parts #s
11115-62071 - HEAD GASKET x1 (these are different for each side. take note when ordering Right and left)
11116-62071 - HEAD GASKET x1 (these are different for each side. take note when ordering Right and left)
13568-YZZ03 - Timing belt x1
90916-03075 - thermostat x1
16325-62010 Thermostat Gasket Aisin x1
90910-02077 head bolts (x16)
90311-40022 Crank seal x1
17173-62050 - MANIFOLD gasket x2 *upper
17177-62060 lower intake manifold gasket x2 (both sides L and R same part#)
13505-62070 - Idler pulley #1: x1
3.4 LITER
13503-62040 - Idler pulley #2: x1
3.4 LITER
13540-62021 - TIMING TENSIONER x1
All Models
16100-69398-83 - Water pump x1 (check to make sure gasket included or need to buy)
3.4 LITER
90080-91090-83 - Alternator belt x1
3.4 LITER
90080-91126-83 - P/S belt x1
3.4 LITER
99364-20870-78 - AC belt x1
3.4 LITER
11213-62020 - Valve cover gasket x2 (right and left are the same if i remember correctly. double check)
3.4 LITER,
90210-05007 Valve Cover Washer Seals (the 16 bolts that hold the valve cover down these are the washers with rubber in them) x16
11193-70010 Spark plug tube gasket x6
11188-62010-Camshaft housing Plug (big round plug on back of the head) x2
12204-62010 PCV Valve x1
90480-18001 PCV Grommet x1
00295-00103 - Trans pan sealer x1 or x2 for spare tube
3.4 LITER "Black FIPG GASKET SEALER"
84261-08041 Knock sensor sub harness (often recommended because of movement, corrosion, and damage?)
00272-SLLC2 TOYOTA PINK COOLANT (check manual for amounts and flush procedure)
90919-01192 spark plugs x6
1717362050 exhaust manifold gasket x2
90917-06083 exhaust crossover pipe gasket x2
96741-19005 Small O-rings for dip stick if removed as seen in the video series linked above
Gasket remover tool
Intake cleaner
Parts cleaner
3.4 LITER
3.4 LITER
All Models
3.4 LITER
3.4 LITER
3.4 LITER
3.4 LITER
3.4 LITER,
Gasket remover tool
Intake cleaner
Parts cleaner
