BlackWorksInc
Okay so this seems to come up a lot and I figured the least I could do is provide what the factory wants you to do when you change the fluid on a Toyota Sealed Transmission using WS Fluid.
Normally you need a TIS TechStream Scantool to get the transmission temperature. But according to a small section of the instructions there is a way to initiate a temperature monitor mode without a scantool. I personally have never done this so I can't say to whether or not it works.
Factory replacement procedure for sealed transmission:
http://freepdfhosting.com/c25eda0711.pdf
This is a TSB with a flow chart showing temperature ranges that you need to be within to properly check the fluid level of a sealed transmission.
http://freepdfhosting.com/32301e6b32.pdf
Small side note- I was talking with another forum member who wanted to change his fluid and he suggested using an IR thermometer to check the fluid temperature via the transmission pan. Since you are looking for an ideal range and not an exact number this should be fine also.
