Toyota Parts questions? just ask.
AIRTOY
Hi,
I am new to the forum and I am a Toyota Master Certified Parts professional and have worked in a large Toyota Dealership since 1997 and am the Asst Parts Manager. I also have owned a couple 4runners and 4x4 Toyota trucks in my day. If you have anything you are needing to figure out as far as genuine Toyota Parts just shoot me a message. I also have a website that has discounted pricing ToyotaParts4Less - GENUINE TOYOTA & SCION DISCOUNTED OEM PARTS & ACCESSORIES
Let me know if there is anything you need help with
-Wayne
Hi Wayne, thanks for the generous offer to help with parts related questions. I have a situation that I need some help with. I bought the full length budbuilt skids (engine, tranny, and T case) and I am unable to get the provided crossmember to mount up. The crossmember is hitting the large plastic pack on the rear of the T case, I believe this is the T case solenoid. I am only getting about 1/2 inch of interference.
When I put my floor jack under the T case, it moves up and down quite a bit with a little pressure. Do you think it is possible / common for the trans mount to be bad? I suppose if the rubber section of the trans mount is worn out, then the whole drive train will sit lower to the factory crossmember.
Can you think of any other reason that the drive train will be sitting low? The Runner is an 07 v6 with about 68k on it. I wheel pretty hard, pretty often!!
thanks in advance for any ideas / advice!
Andrew
