Toytec adjustable kit for 5100s
Riddler6.7
I did search and didn't come up with any good info.
Just curious if anyone has the toytec adjustable kit for the 5100s. Anyone know what the spring rates are?
I was originally planning on just getting OME 884s for my 5100s, but I plan on getting a slimline bumper and winch in the future. I think that something adjustable would be a better option then just springs.
Anyone with this kit? Thoughts? Sway bar brackets and radiator supports really needed?
Adjustable Front Coil Over Kit for Bilstein Shocks 2010+
Sent from my SAMSUNG-SM-G890A using Tapatalk
Here http://www.toyota-4runner.org/5th-gen-t4rs/165065-5th-gen-4runner-lift-buyers-guide.html
My toytec ultimate's which I believe are the same as that kit has 600# springs. Call toytec and ask if they have options ! Oh and mine has kdss so no radiator or swaybar drop.
i found that the sway bar relocates were pretty much a requirement to keep adequate spacing between the springs and sway bar (could this be mitigated with extended sway bar links?) Once that is relocated forward the driver side radiator support bracket (which mounts closer to center than the passenger side) did come into contact with the sway bar and actually has just enough clearance with them installed.
discussions with toytec indicated this is an disassembled version of the Ultimate kit without the new top-hat. springs are the same.
How close are your UCA's from the tire? I had my Toytec lift installed with the SPC's and one side has an inch+ but the passenger side has maybe a quarter inch. It rubs in reverse so I have to go back Monday for them to re-adjust the alignment.
Thanks for the info guys. I wonder if the springs they are using are larger O.D. and cause clearance issues, or if I would need the brackets etc even if I went with the O.M.E. springs. I did email them yesterday with questions as they were closed.
Toytec or Revtek 3" lift info'
Hi, Just got a 2016 4Runner Trail with KDSS
looking into a 3" lift , im far from being an expert.
Anyone has an experience with Revtek lifts ?
Thanks.
Just wanted to post an update. Toytec got back with me. The springs are 600lb springs.
