ToyTec Superflex Rear Coils
It shouldn't be too bad.. I'll get a measurement when I take them off and compare them to how tall a new set are. I've got the specs on hand.
Okay, thanks. Let me know. Also, what's your distance from the center of the hubcap to the fender? Just something for me to look at and compare to with my current springs.
Resurrecting this from the dead, sorry not sorry.
This thread had me worried about noise when I was shopping for a lift. I ended up going with the TT 3"/5100 front, and SF/5100 rear.
The superflex springs now have a good bit of rubber already on the coils out of the box. I haven't experienced any noise whatsoever in the few months I've had them.
Just figured I would update for those who might stumble across this thread while doing research.
I didn't take any photos, but you can see some of it on the tight coils here.
I love the setup, I've had it loaded down with a short block iron engine, trans, some oxy/acetylene tanks, and a few other odds and ends. Had no sagging that I noticed and rode great.
Geez, under stock load it's 3.75: of lift. Talk about hella rake. I'd suggest these aren't for everyone. Hell, I probably wouldn't run them without a plate aftermarket rear bumper.
not even close. my settled to less than 3inches of lift. brand new looked amazing. now level.
Yep, my Toytec Superflex coils have been quiet for all 4 years I've had them on. They came with the rubber on the tight coils like the picture above. They haven't sagged over the 4 years either, still at the same height as when new.
My superflex have been all good too & haven't heard any noise since I installed them about 1.5 years ago with daily diving and occasional fire roads. They handle well for my purposes. Ride similar to the 890s I had before switching to the superflex. Will update if I start hearing stuff.
Reresurection! Did most people install the driver's side coil spacer? I know the springs are supposed to compensate, but I have one anyway. I'm hoping to install the springs tonight.
Driver's 10mm spaceror not with superflex??
Sent from my XT1585 using Tapatalk
When I had Toytec superflex coils installed. I had to install OME 10mm Spacer on driver side. ( which is BS due to the fact that Toytec states , these coils eliminate the need for a spacer. )
Glad I got one then. Did you need it right away, or after a while of usage.
First I ran it without. And noticed it right away that driver side was leaning. So just put it in. And double check to make sure your installing the correct coil on the correct side. Some people can confuse them selfs with driver side or passenger side depending which way your looking at the vehicle
Thanks, I believe they are labeled L (driver's) and R (pass). I think the driver's may be slightly taller also.
Good. But , if your facing the front of the truck. The orientation is different then if you are sitting in the truck. Feel me ? Just make sure
The drivers side is the drivers side regardless of how your facing the vehicle. It's the side with the wheel. lol
I did not use the spacer. 4 years, still level.
