Lindenwood
Goodness! :trophy:. I will load my 4Runner with 1300 lb this weekend and test it on railroad tracks and speed bumps to see how it handles them.
So after reading this comment is it safe to say that if you load down your new springs for a few weeks straight they will "set" quicker?Well, I loaded up my 4Runner with 1300 lb, filled it with gas and took it out to test it. This is with new OME 2906 rear springs and Bilstein shocks all around with original stock front springs. First some local railroad tracks; too smooth, barely noticed them. Next a serious railroad crossing; I went over the hump at 35 mph and went slightly airborne; upon landing, the rear bounced several times, but no bottoming out.
Then to the speed bumps, it took the speed bumps very well (25 mph), hardly any different than a rough road. Then, I unloaded the weight and did it again empty. Going slightly airborne at the railroad crossing, it landed firmly but gently with no bounce. On to the speed bumps; with the empty vehicle speed bumps were the harshest of all, much more noticeable bump than with the loaded vehicle.
On the highway, the load was hardly noticable, but on long dips, there was a slight bouncing in the rear. With the vehicle loaded to GVWR, the ride height was 20 3/8 inches rear, 20 5/8 front; upon completion with the vehicle empty it was 22 1/8 rear, 20 7/8 front. So, about 1.75 inches drop in the rear with load, about 0.25 inch front; it looks like the rear has settled about 1/8 inch since the springs were first installed last month.
Haha alright, thanks. Btw I'm curious what that 1,300 lbs consisted of in your rig. I didn't think a 4runner could take that much.Based on a statistical analysis of 1 out of 1, it appears to be true.
How's the ride empty and what kind of lift do those springs give you in the rear?The GVWR is rated as 5250 lb; the curb weight is listed as 3975 lb, giving a payload of 1275 lb. maybe I was slightly overloaded. The payload was me and about 1120 lb of barbell iron. I balance it out with 400 lb in the front seats, 400 lb in the back seat, and 500 lb in the rear area, to represent 4 fairly large people and cargo or a trailer. I have loaded it to this level many times in real use. Usually concrete blocks or sacks of mortar and another passenger, and once 4 people, luggage and a trailer about a thousand miles and back, so testing it with a payload of 1300 lb is not unrealistic.
Before the OME 2906 springs, it really felt very overloaded. I have been planning to fix it for many years and finally got around to it. Now it is how I think a 4Runner should be.
Here's the sleeping platform/cargo box. It probably weights about 100lbs total, maybe a little more or less (not quite sure) but it's all 3/4" birch, so maybe a little more. The front box is only for food and stove, and the cooler straps into the rear seat locks (dunno what to call them), so a lot of the weight is pushed to the rear.
As of right now, I'm going with the Superflex springs unless anyone says otherwise
