Toytec Ultimate Lift and Alignment Issue?
Former_Jeeper
So the other day I installed a toytec coilover ultimate lift on my 99 4 Runner. The adjustables are actually lowered down quite a bit to match the OME 906's in the rear. (2 in rear lift). And I took it to the alignment shop and they couldnt get the caster to within factory specs. I know some guys replace the UCA, but this is more of 2in and not quite pushing the 3in front mark.
Currently the caster is 1.1 to the left front and .9 for the right front.
Or could it be that when I adjusted the coilovers maybe the alignment is supersensitive to both have to be exactly the same?
Help is appreciated
It doesn't take much to knock the caster to a point where it can not be brought back with the stock upper arm. There isn't much manipulation on the lower arm adjusters.
patnewton
