message
Member
Good article on the functionality of TPMS as well as how easily the system is compromised/fooled.
Data Leaks: How My Car Betrays Me
Interesting article, but I'm not sure that I understand their point with TPMS. Each sensor does transmit a signal, but it is a very weak signal and could not be picked up from far away. The range is short because there's no need for it to travel big distances. So if you're close enough to pick up a TPMS signal, then you're close enough to read the VIN plate on the car or any other means of identifying it.
So what are they trying to say?
Jed, you're back!
Anyway, my issue with the TPMS sensors is that the batteries will eventually die ultimately triggering the dash light.
Jed, you're back!
That does not make sense, no pun intended. It would make sense to only transmit when low pressure is sensed. I have never heard of a battery dying in a sensor.
Koz
Koz
Figure the distance from your rear/spare tire to the TPMS system, which is behind the glove box is about 6 or 7 feet? That is plenty space to read and/or fool a TPMS system whether it be driving through a toll booth or some punk hackers passing you in another vehicle.
I'm curious as to the actual range of the TPMS system since it does run on RF.
The sensor transmits constantly...well, maybe not constantly, but in set time increments.
Also, Toyota already claims a life expectancy of 7 years for the TPMS batteries. This is published info in their own literature.
The reason you haven't heard of it is that battery operated TPMS are still relatively new. I fully expect to start seeing people with '04 4Runners (first year of TMPS for us) posting about failing batteries within the next few years if not sooner.
I think the car would have to be stationary, at least for a minute or two. In the article, it was stated that the sensor transmit a signal every minute or so... Simply passing through a toll booth wouldn't be enough time to capture the data.Also, I remember reading somewhere that the sensors go into a sleep mode and stop transmitting when the tires are stationary for a while, so that might make it even MORE difficult for someone to capture TMPS data.
All in all, this was an interesting article. But it is just too far fetched to even worry about. I remember when people were complaining about EZPass being an invasion of privacy because people's routes could be traced. Although that is true, nobody seems to care much, other than maybe law enforcement when they are trying to prove someone's whereabouts at a specific time or location. It's really a non-issue for 99.9% of the public.
To me another great way for dealerships to make lots of money, I disabled my system after finding that (3) count them 3 went bad somehow. For a proposed cost of $768 installed.... yeah right.
I think a lot of members will love grounding out the TPMS system in the future to get that dang light to stop winking at them.
Jed,
What makes you think I have not heard of battery operated TPMS, I had a 05. What does make sense is, a transmitter that only uses power when the sensor is triggered by low pressure, especially with a sensor that the battery cannot be replaced (If that is the case).
Koz
You will soon see battery-less direct sensor systems which require zero maintenance and are very reliable.
Koz
They already had that type of TPMS before we had the current battery operated ones. The early TPMS used the wheel speed sensors for the ABS to determine if a tire was low on pressure. The idea is that a tire that is low will have a different overall diameter and a different rotational speed. Then they moved to the individual sensors in each wheel. As for the future, who knows?
i wonder, and i know there most likely is, a way to get rid of that stupid tire light on my dash. i no longer have tpms on any wheels and want to make the tpms light go away.
any ideas of a simple way to get this done?
