Tpms sensors
To add to the above post... did you buy a certain tmps sensor or do they all typically work since its a certain frequency. Having the exact pressure is nice too.
Sent from my SM-G975U using Tapatalk
The psi/temp info comes from the OBD2 port (from the sensor).
The idatalink Maestro has a cable to the OBD2 port (and to the head unit).
I use Toyota /Denso sensors. Other manufacturer sensors that function with the OEM system would work.
Best buy says that the Pioneer DMH-2660NEX does not fit 4th gen runners. Did you have any installation hassles?
When I initiated my research, Crutchfield listed the 2660NEX as "Not fitting" the 2007 T4R. I did more digging and found out it does fit, and with no issues.
The Metra 95-8202 Dash Kit Item #120958202 is what is depicted in the pic.
