tpms test
palooka23
How do I check to make sure the TPMS is working properly?
I thought I had a tire that was lower than 27psi and I did not get a indicator light.
I have an 07 sport with stock wheels and tires.
Thanks in advance.
Make sure all tires are inflated properly ,
let the air out of one tire.
Note: (to save time you can remove the core or use a deflater) The light come will come on and stay on untill tire is re-filled.
This is how I tested my tpms disable mod.
when you mean your tpms disable mod, do you mean you just messed with the wiring to disable the light on the dash?
Thanks in advance.
tpms runs a diagnostic at startup.. the light should come on momentarily when you start the truck.. if there was an error, it would flash (continuously) and the pattern of the flash describes the type of error encountered.
