Traction Control Switch Reset?
keith&julie
I have an 07 T4R that does have the factory TSC switch. It used to work but when I tried it today, it does not turn the traction control off. I can't remember if the switch has a "click" to the toggle like the hill assist does, but this one does not click. Is there a reset or something for the traction control?
I didn't think that they started including that switch until 2008, but that might be the "VSC-Off" switch. Do you have a 2WD? What trim level and engine option?
And those switches are usually momentary switches controlled by a relay... that way, when you turn off the vehicle and then restart it, the system is active again. The default position is active.
That switch shouldnt click since its momentary. In order to turn off the system it has to be held for (iirc) 3 or more seconds.
