Trade? SC300 2JZGTE-V160 - BIG DIFF-KW V3
mikeferg
Not sure if I can post this here, This is mine and looking to trade for a 4runner.
Mike and my phone number is 9546383900
Nearly Mint 1993 Obd1 Sc300
$22,000 or trade
Denver, CO
The truck would have to be the same value about. but we can just work on a deal.
Have about $35,000 invested in to this project, Full receipts.
here's the specs and photos
This is a fine example of an amazing sports coupe, everything was done to spec, Never been raced or seen snow. The car lived most of its life in Florida. The CarFax is clean. I have a full list of work done to it with Receipts on all the work.
stock twines are still at stock boost. NEW Discontinued v160 and all the parts from the dealer
This is a 190+mph car that is ready to make some serious power
2JZ GTE V160 Parts List
6-speed drive belt tensioner
16620-46070 tensioner list 243.36 cost 182.52
16621-46010 bracket list 50.22 cost 37.66
16622-46010 arm list 23.96 cost 17.97
16602-46010 shock absorber list 77.66 cost 58.24
91511-g0845 bolt list 1.24 cost .93 x 2
90901-16001 stud list 2.79 cost 2.09
90179-08171 nut list 1.21 cost .91 x 2
90116-08348 stud list 1.15 cost .86 x 3
90080-17242 nut list 1.78 cost 1.33 ex x 2
Transmission
33030-0w212 v160 assy new $6300 (Discontinued)
31123-14020 inspection cover cost 30.38
31121-14030 inspection cover cost 36.65
90080-11228 bolt cost 3.28 total x 4
08885-01306 v160 oil qt cost ea x 2 Check to see if its prefilled/ checked ok
57255-14231 CROSS MEMBER, cost 173.23
90980-11051 Toyota HOUSING, CONNECTOR F cost 5.19
82998-12440 terminal for the housing connectorsx2
58261-14010 upper trans tunnel cost 80.33
90159-A0045 Screw, W/washer 2.92
12371-46110 trans mount list 87.92 cost 65.94
Shifter
33504-14130 shift knob cost 92.08
33511-14031 control shaft cost 25.86
33513-22030 yoke cost 7.87
33530-14442 93.5-95 short throw shifter cost 133.56
90301-11015 o ring cost 12.16 total x 4
33531-14010 boot cost 40.42
90387-08134 collar cost 4.22 total x 2
33555-14110 boot cost 38.38
33555-14100 boot cost 10.17
33556-14050 seat cost 1.63
33057-14010 bracket cost 45.94
33570-14070 shifter tri-pod cost 97.65
93381-16016 bolt cost 3.04 total x 4
90179-08095 nut cost 2.46 total x 2
90105-08200 bolt cost 2.06 total x 2
91651-60835 bolt cost 6.08 total x 4
90105-08076 bolt cost .79
90179-08233 nut cost 1.03
90250-06026 pin cost 1.18
90467-21010 clip cost 2.46
33546-22020 bushing cost 29.00 ea x 2
Clutch parts/pedals
SC300/SC400 5 speed conversion pedal set $355
58280-14080 boot/plate assy list 25.72 cost 24.33
SC300 Manual Shifter Boot $58
31470-14060 slave cylinder list 83.38 cost 62.53
90080-10055 bolt list 1.21 cost .91 x 2
31410-14310 master cylinder list 150.31 cost 112.73
90179-08237 nut list 1.24 cost .93 ea x 2
31481-14260 tube list 32.07 cost 24.05
96816-50335 hose list 31.09 cost 23.32
31484-24010 bracket list 8.48 cost 6.36
31482-14060 tube list 15.00 cost 11.25
90119-06406 bolt list 1.01 cost .76
96991-10080 clip list 1.58 cost 1.18 ea x 2
90119-06733 bolt list .95 cost .71
00475-1BF03 brake fluid pint list 5.81 cost 4.36 ea x 2
90363-12002-77 BEARING,PILOT LIST 8.65 COST 6.49
96152-00500 RING, SNAP LIST 3.36 COST 2.52
90903-63001 BEARING , RELEASE LIST 81.00 COST 60.75
90560-50001 SPACER LIST 7.36 COST 5.52
90560-79001 SPACER LIST 3.02 COST 2.26
90206-12006 WASHER, LIST 2.01 COST 1.51
90520-75001 RING, SNAP LIST 3.74 COST 2.80
31264-14060 SPRING, LIST 3.74 COST 2.80
31231-14050 HUB, LIST 44.28 COST 33.21
31204-14060 FORK LIST 88.70 COST 66.52
90119-08079 BOLT, COVER LIST 0.75 COST 0.56 EA X 6
90910-02115 BOLT FW LIST 12.18 COST 9.13 EA X 8
13450-0W011 FLYWHEEL LIST 831.35 COST 623.51
31210-14170-84 REMAN COVER LIST 174.02 COST 139.61 [ includes 7.00 core charge ]
steering reservoir. 44360-24042
ClutchMasters 16000-HD00-R FX100 Stage 1 Clutch Kit Toyota Supra $660
RPS Cyn-R-G Aluminum Segmented Flywheel for 1993-98 Supra TT BF-22170 $474.05
Rear Differential/Driveshaft/Axles
Diff JDM 3.26 LSD supra $2500
Custom driveshaft (Drive shaft stop) Rated 1000HP $850
Rubber rear driveshaft coupling from supra TT 37511-30020 COUPLING, FLEXIBLE cost $307.06 price $228.72
42340-14140 lh drive axle list 568.87 cost 426.65
42330-24030 SHAFT ASSY, RR DRIVE cost $437.10 price $325.58
Oil pressure sensor mod / Gauges
90401-19008 union bolt $33
90430-20016 Gasket $1.28
90301-68005 O-ring $3.67
VDO-360086 Sender press 100PSI 1/8 $32.29
VDO-350106 Gauge press 100PSI CV $44.99
VDO-150121 Gauge Turbo Mech 30HG-25 $59.99
Auto Meter 3222 Nylon Tubing$6.72
1/8 NPT TO 1/8 BSPT $11.21
T-FITTING ADAPTER FOR BOOST GAUGES POWERSTROKE MAP LINE BOOST LINE 1/8NPT DIESEL
VDO-150851
Fuel Pump
Walbro 255 in tank fuel pump with setup kit $100 plus ECU fuel pump $49
Engine
2JZ GTE supra swap $3930 with cat (came from a Supra clip with less then 15k miles)
CX Blow Off Valve $60
CX Racing Intercooler for 1993-1998 Toyota soaror $494.10
Other
fipg sealant $20.50
Fan Shroud for supra 92-00 $199.00
MIO-MMRADSUPT Radiator $285.00
Tweakd Performance wire harness $825
Old new stock Floor mats $200
95 Tail lights $150
KW V3 Coilovers $2000
Sc300 $6000
Wheels $1407
LS400/Supra TT rear calipers and goodridge lines and R1 rotors $1250
gallon toyota red coolant
clutch fluid and power steering fluid
Garage kept.
hello:
beautiful car!
I am Toyota /Lexus fan
Soooo..
have a 2007 sr 5 sport v6 4x4..
Dark steel Gray with blue metal flake
loaded rig ,
3rd row etc,
no nav, no leaher..
new tires , brakes , shocks,clean..
adult owned..105,000 miles
rig is worth $10,500 -$13,000
any intreats plus cash?
Thx RR
hello:
beautiful car!
Soooo..
loaded rig ,
3rd row etc,
no nav, no leaher..
Thx RR
Hello, Do you have a link with photos of it? is the title clean?
