Just installed Tekonsha Primus IQ and seeing the same issue. Have not experimented with it much yet. Camping trip coming up in a month, hoping we will hear back by then.
I wish they would get this figured out already.
Just ordered the diodes!You can do it!
No more codes!
Thank you for this. I so hope it works!
The NEEDED basics are welcomed. The pics detail it perfectly and your follow up post above was helpful.You're welcome... just make sure to observe polarity -
A diode allows power to flow from the anode to the cathode but not the reverse -
In our case we want power to move from the truck to the brake controller, but not back.
Usually the cathode is the side with the ring, observe the orientation in my pics...
Anode to truck side, cathode to brake controller side.
Sorry for the probably unneeded basics! I think gm350reratliff gave a far more complete explanation near the beginning of the thread, I just took pics...
No problems with my Tekonsha Prodigy P3 after towing almost 4,000 miles. Tested the manual override - everything works as it should.
Are you guys using the plug-and-play wiring harness (p/n 3040-P)? Note this is not the one that came with the truck, or with the controller. It has to be purchased separately:
Amazon.com: Tekonsha 3040-P Brake Control Wiring Adapter for Toyota: Automotive
I spoke to someone at Hopkins and they said they are also working on a harness for the 2015 Toyota's. He said that on the unit I installed, the controller monitors voltage on the red wire to know when the brakes are being applied, and applies voltage to this wire when using the manual trailer brake override for brake light operation. This would mean a diode would not work properly on the Hopkins unit. Waiting for Hopkins to get back to me......
From what I can see it's a problem with 14+ 4runners. I little change in the ECU flash and now folks have to do this. Silly Toyota.
I received a new harness from Tekonsha. Will install this weekend.
