Kind of sounds like the clutch packs are bad in the tranny, but it's hard to say from the description.
I'm surprised you came out pretty good. Transmission work isn't fun or cheap. Did you ever change the fluid in the transmission? How many miles are on it?
put another solenoid in and still throwing codes. said the trans wiring harness seals are bad and fluid is getting onto wires and causing it to throw codes. i was told the harness is not made available by Toyota. they contacted their field rep to see if a harness could be made and wont know until at least monday if its possible. if not its a new trans. $2000.00 at least. unreal.
any ideas anyone ?![]()
