Trans temp with torque pro?
Brian3676
Was going to get the scan gauge II, but decided to try the bluetooth OBD2 adapter everyone talks about on Amazon.com, and download the torque pro app. Seems I can read everything I could ever want to with this besides tranny temp! I also have a $350 scanner that does ABS, SRS and engine and that also does not read the tranny temp. I can read temps on other cars, but not Toyota. It's like they locked it so your forced to use the ghetto jumper wire method or go to dealer.
Anyone got the torque pro app to read tranny temp Somehow?
you have to create new custom PIDs in the Torque Pro app.
Tranny Temp 2
Long name: 21d9
Min value: -40
max value: 440
Unit: F
Equation: ((((G*256)+H)/256)-40)*1.8+32
Tranny Temp 1
everything same as above except the equation which is
((((E*256)+F)/256)-40)*1.8+32
I'm not sure exactly what each temp reads but they're the same at idle... when you begin moving or accelerating, they seperate with a delta. I'm guessing one is the tranny pan and one is after the integral radiator cooler.
Ambrose67
