Transfer Case Oddity
kiehen
Hey All,
Picked up my 2000 4Runner w/64k on the clock on Saturday. Took it out on a couple trails on Monday, so that was first time I ran it in 4WD for any longer than a couple minutes. Was out for a couple hours. Got back to the highway, everything seemed normal until I hit the freeway (which is about 45-50 minutes from where I hit the highway). Then comes the drone. Fairly audible at freeway speeds. After some experimentation, I've discovered that the drone is at it's worst between 50 and 60 mph, and doesn't start happening until 50 mph almost on the dot. Couple this with noticing that the (manual) shifter was getting warm even after short periods of driving. That part didn't bother me too much prior to the drone starting, since I vaguely remember that happening in my dad's '02 Tundra V6 5spd on a regular basis. Fast forward to today - 60k service at the Toyota dealership because evidence indicated that it had not yet been performed. After the service, the tech tells me that my transfer case was dry. No evidence of a leak anywhere, but there was no fluid in there. He wasn't sure if there was damage. I spent about an hour tonight out on some dirt roads running it through H2, H4, and L4, then went back out to the highway. Same thing. Loud drone at 50, shifter very warm.
I'm worried that there may be some irreversible damage. Can anyone speak to this? Am I looking at a new transfer case? I'm calling the tech at the dealership back tomorrow to chat about it, but I wanted to tap the vast knowledge on here as well.
Was the trans fer case dry on the out side or was it dry on inside.
If it keeps messing up when you take it out of 4wd. What happens when you leave it in 4wd and drive down the road?
Is your 4wd blinking?
does it have an aftermarket exhaust?
It sounds like the the front ADD is not disconecting. Maybe a bad valve or hose.
if you ran your truck in 4wd with the t-case dry then yes id bet you pretty much just burnt up your t-case. the fact that you said it would drone and the shifter got warm, yeah... the drone is coming from the bearings, and gears heating up and not having any lube -that heat is then transferred to the shifter and thats why you were feeling it.
BillM777
