Transfer case output flange studs
UnderFire
Trying to find some information about where or how to get ahold of a set of studs and nuts for the output flanges on the 4runner.
Front is M10, Rear is M11, I need a full set of each with nuts, Local dealer doesn't show anything under the 4Runner (Maybe Part Numbers from other trucks, or just for the studs?), NAPA has nothing, Local hardware shops nothing.
I found a P/N from a Land Cruiser.
90114-11124
Supposedly it's a serrated 11mm bolt, but that's all I can get, hopefully someone can help.
I don't know, but please post an answer if you find one. I'm running three right now on the rear, and if I can't clean up the threads on the fourth (die is on the way from China), I'll try and fake it with a regular high-grade bolt. I couldn't find it.
M11 is pretty rare for anything.
when did they switch to studs? id have to check, but I think my 06 has bolts...just the same as my 85's. I haven't seen any with studs yet.
a nut and bolt would work just as good.
Must've been a 1st gen taco/ 3rd gen 4runner thing, it's out of a 96 Tacoma, I know the Pre-96 trucks ran bolts as well, an M11 Nut/Bolt would work fine, but I can't find them either, the pretaco trucks ran M10 on both sides.
Here is a pic of the beast:
would a 7/16" bolt fit? its just a SMIDGE larger than an 11mm.
Local ones have all the trannys pulled before they hit the yard, but I'm going down to a big toyota one Monday, so hopefully I can get a couple sets.
That sucks! They are like gold, I've wrecked a few toyotas and always grab all the driveshaft bolts/nuts. lol
FoxyMama
