Transmission cooler
KENGNJ
I had my mechanic install a new transmission cooler in my 2016 trail, now my air conditioner is not cold. What could they have done to mess this up?
Hopefully the mechanic didn't cross the transmission cooler line with the AC condenser line, but the mechanic would be the first person I asked. Or...somehow the added heat of the transmission cooler/radiator is located in front of where the AC condenser is supposed to get cool air to bring the refrigerant back to liquid.
Do you have any pictures of the cooler or how it was installed that can shed some light on the issue? You couldn't of picked up a stone shot to the condenser on your way back from the shop for all you know.
Figured it out
My guess is knocked a wire off.
Does compressor run?
WanderMT was right, either they forgot to plug in this connection or it came lose.
This is a wire just in front of the radiator, plugged in back in and nice cold air started blowing. Took longer to take off the cowl.
Thanks for the ideas.
Ken
[MENTION=139416]KENGNJ[/MENTION]
So glad it turned out to be a simple, quick fix!
Good call [MENTION=117129]wanderMT[/MENTION]!
Follow up questions I have torque on my phone but it doesn't display transmission temperature, can this be added?
Sent from my SAMSUNG-SM-G900A using Tapatalk
If you search my posts, I have referenced it a few times. There is a csv file you load to Torque.
Sent from my Moto G4 Plus using Tapatalk
