Transmission Filter & Question...
RedMenace293
Does anyone know if any of the national auto parts chains (O'Reilly, Autozone, Advanced Auto Parts, etc) carry in-line transmission filters, similar to the Magnaflow ones I see everyone recommending? I did some searching on google but could only seem to find the internal filter replacement kits.
The reason I need to find one at a brick and mortar store is because I was in the middle of replacing my radiator and installing a B&M tranny cooler (the 70264) today when I noticed my fluid is a dark murky red (see pic) and figured it'd be a good time to change it out while I have the lines accessible. Was planning on using the flush & fill method where you drain the pan, disconnect the send line, and let the truck pump the fluid out while refilling at the dip-stick. Wanted to change the trans filter as well, but unfortunately I do not have a torque wrench, nor a lift so I can drop the sway bar, and it sounds like removing the FIPG gasket might be a pain as well, so I was wondering if installing an in-line filter would accomplish roughly the same thing in terms of improving AFT filtering?
My truck has close to 180,000 miles on it and I don't know anything about the previous owners maintenance, so I'm going into this assuming the transmission has never been opened up or serviced.
Ignore the bug that drowned itself in the transmission fluid, I let it drain overnight and came out to this haha
Also, any recommendations for specific brands of transmission fluid?
Was planning on just picking up 2 gallons of Valvoline Maxlife DEX/MERC for $36 at my local autozone, but would be open to spending a few more bucks if there is something I could get that would give significantly better performance over the Maxlife.
ATP JX-160 3/8" Universal In-Line Filter
Amazon.com: ATP JX-160 3/8" Universal In-Line Filter: Automotive
B&M 70268 SuperCooler Automatic Transmission Cooler
Amazon.com: B&M 70268 SuperCooler Automatic Transmission Cooler: Automotive
My set up that I did, I know it's not the right way but I just been draining and refilling about 4 times within a week since I had a buch of left over trans fluid, I haven't replaced the internal trans filter yet, I'm sure in the near future I will get to it, I got all the info I needed from TRD Transmission Cooler - 3rd Gen 4Runner - YotaTech Forums and you should be good to go
At what point in the trans lines did you install the filter? Would love to see a pic of your setup if you took any, haven't ran the lines to my cooler yet and would like to do so with placement of the filter in mind as everything is pretty tight in there
I haven't taken any pics but I did the same set up as kball in the link http://www.toyota-4runner.org/3rd-gen-t4rs/63553-writeup-tranny-cooler-install-5.html so the top hose would be the sending line which I installed the inline filter and bottom would be return line, all together took me about an hour to install maybe less. Not sure if you read any of the how to's but keep in mind you do need to purchase about an extra 4-5 feet 3/8 trans hose, the b&m kit only comes with one hose and is enough for either sending or return line doesn't matter, it's a really straight forward task and really can't mess anything up! One more thing is if your old hose is in good condition keep one of them so you can bypass the radiator cooler, as in you use one hose to plug both both ends if you get what I mean?
Laredotx
