Transmission Issue?
milgrad
OK I bought my wife an 08 Urban 4runner last month...We have had this weird issue happen several times now. When in reverse and putting into drive it takes several seconds for it to go into drive. We can press the gas and the engine revs, but the vehicle does not move. Any ideas? I have an appointment for later in the week at the dealer...
Maybe a real problem or maybe the fluid level in trans wasn't properly serviced. Good luck!
Dropped it off at the dealer this morning..They said it was fine...UGH...it did it three times before I took it in....
What I notice on mine is the R to D or N to D is slower than other cars I have owned/driven. If I get too fast and step on the gas prior to the shift being complete it actually delays the process. The computer holds the engine power way down in spite of my foot being on the gas and then it almost lunges as the transmission signals the engine to "let it rip, I'm ready". It's almost like there's a Nanny feature to help prevent the 16 year olds from doing Nuetral drops:bash:
I am not say your car is normal, I don't know. I am saying "normal" is a bit different in the case of the T4R.
:cheers:
I will have to watch for this but so far I have not noticed any slowness in getting going while changing from R to D.
This may be a different issue, but my '04 (and other 4th gen V8's) will sometimes slip a little and then engage harshly when going from R to D. I noticed that if I pause in N for a second or two, instead of going straight past it to D, it never has this problem.
Now when I back up, I move the shifter from R to N a little early and let the vehicle coast for a few feet before applying the brake and shifting to D.
Show the dealer what it does when you drive it from R to D.
Unless the problem is unique to your vehicle, it's unlikely the dealer will do anything unless there's a catastrophic failure. All of Toyota's design oversights are dismissed as "normal" or "within specs". Generally when Toyota's engineers screw up, we all live with it unless there's a class action lawsuit. It sucks, but that's how Toyota's "warranty" works.
I owned a 2008 4Runner 2WD, and have the same problem especially on the boat ramp on an incline. Also shifting from R to D.
The problem is not all the time.:mad:
My 04 V8 does the exact same thing. I happens more then the tranny is still cold. When it warms up it gets a bit better.
I'm wondering if the fluid is possibly low? Its hard to tell, since there is not freaking dipstick, and there is a lengthy procedure on how to top up the fluid anyways.
Is there a low level alarm for the trany fluid?
Anybody else have any suggestions for fixes?
