97blkt4r
Car: '97 Toyota 4runner 4wd Automatic 144,000 miles
Problem:
There are times when I am going to start driving and when I push on the gas the car revs as if it is in neutral, but it's in drive. Then after a few seconds it makes a noise (sounds like 'breek!') and jerks forward and I can drive away. Usually, after this happens, when I'm coming (and I'm almost stopped) the car will make a noise and jerk to a stop. Most of the time when this happens the car will not roll forward when there is no foot on the brake or gas and it's in drive (normally, like all automatics it would roll forward). It is as if there is occasionally a problem where the transmission is slipping out of 1st gear into neutral when coming to a stop and not wanting to go into 1st gear when it is put from park to drive.
I took it to AMMCO and had them do a free diagnostic on it. They said the fluid level is good, but the fluid is varnished. The scan for codes and no codes came up. They didn't see anything visually wrong and when they test drove it (multiple times) the car did not present the symptoms I wrote about above (it is an intermittent problem). They said they could charge me $600 to take the transmission off and inspect, but they could add more labor charges on top of it if they discover the problem and replace a part, so I'm not quite ready to do that. They said I should change the fluid, filter, & gasket $115, but since I think the problem is more then just needing new fluid I just assume having the fluid changed when the repairs are done so that there is no additional charge.
My questions are:
What is the likely cause(s) of these issues?
Would all of the likely causes be very apparent if the transmission was removed (I would hate to have them inspect it and not find the source of the problem)?
What is your guess as to the cost of the part(s) of the likely cause(s) would be? In other words, if you think part x may be busted, then how much would you guess it would cost for the replacement part.
Thanks in advance for any info & sorry for the long explanation.
Problem:
My questions are:
