Transmission Temps: Observations and Revelation
OrdnanceMarine
I just finished my first camping trip towing my '06 Jayco 1206 camping trailer and had just received my ScanGaugeII back from the firmware upgrade that allows transmission temp to be displayed and wanted to post some observations. I also did some steep extended trail driving up to what was one of the largest silver mines in the United States, Cerro Gordo (second only to Virginia City - Comstock).
My trailer is rather large for a pop-up and was probably in the 3200-3300 lb range on game day so between that and what we had in the tow vehicle itself I'd estimate we were rolling with 4000 lbs of payload. We towed from 2300' and 100 degrees outside to 3700' and 95 degrees and with a few light to moderate grades along the way with the air conditioning on all but a few times when I wanted to see if eliminating that parasitic drag would help (Highway 395 from Ridgecrest to Lone Pine).
Right away I picked up that if the transmission was in 4th or 5th and the torque converter was locked up then the trans temp would be around 175 plus or minus about 5 degrees. When the torque converter unlocked the transmission temp would immediately begin to climb. The longer the grade, the more the climb, getting up to around 200 before I'd either finish the climb or if it was in 5th gear, before I'd bump it to 4th and once the torque converter locked up, the temp would quickly drop back to ~175. This was very predictable and allowed me to bump the transmission in to 4th just ahead of an incline so I could both maximize fuel economy while preventing a mid-hill shift from 5-unlocked to 4-unlocked and helped keep the temp down.
Then I turned off of HWY 395 and climbed up a fairly steep grade between 25-35 MPH, going from 3700'-4800' in 2.5 miles. Here transmission temps quickly rose into the 220s during the first mile and over the next mile went up to 240 so I pulled over and let it rest in neutral for 2-3 minutes and the temp dropped to 220 and I finished the climb, peaking again at 240. At no time did the engine have any trouble pulling the load; instead I was concerned about cooking my transmission.
We made a turn and I accelerated on a slight downhill until I could get 4th gear to lock up and as soon as that took place the temps dropped below 200 fairly quickly. Another 2 miles and we turned up the trail to our campsite and climbed 400' in about a mile at about 10-15 MPH and temps gradually climbed but didn't exceed 225.
I let it run for another 5 minutes while I backed the trailer in to the site and got situated. While there was plenty of heat pouring off the car nothing smelled hot. Bottom line here is that if you're not in 4th or 5th gear with the torque converter locked up then the transmission temp is going to climb above "normal". If the torque converter is locked up (only in 4th and 5th gears, right?) you can tow as fast and as long as you want with no rise in temp. How high the temp gets with the torque converter unlocked depends on how steep the grade is and how long you're running it (I'm sure ambient temps has an effect as well).
The next day my folks came along in their 4Runner (2008 V6 4x4 Limited) to Cerro Gordo. Here you climb from 3600' at Keeler, CA (old shore of Owens Lake) to 8200' in pretty short order. The first mile or two is a gentle climb out of the valley and then it turns in to a consistent steep grade for maybe an additional 5 miles. The trail is in good condition and has the typical broken rock, sand and dust that accompany many of the trails in the Mojave Desert and surrounding mountains. I drove the first section with the transfer case in 2H then switched to 4H about 1/3 of the way up. Transmission temps were in the 220-230 range through here (not towing anything). Then I went ahead and shifted to 4L and transmission temps stabilized but the grade increased some. Out of curiousity I switched back to 4H and was in 2nd gear and temps quickly climbed to 242 and showed no sign of stopping so I shifted back to 4L and the temp stabilized at 235-237 the remainder of the climb. Bottom line here was even though 4H was getting the job done, 4L was giving me a slightly cooler transmission temp.
I have plans to haul this trailer all over the Sierra Nevada and surrounding mountains with many destinations taking me through extended steep and slow grades back canyons, trails etc. so I am pretty much convinced I need to find a good way to keep my transmission from burning up.
Does anyone have good suggestions for a transmission cooling mod for this situation? Right now I think that an aux cooler in front of the radiator alone may not be enough. Will I need to add a cooling fan to it to get the performance I want, especially for slower speeds when airflow won't help to cool things as much?
Any suggestions?
By the way, I was very happy with the fuel economy while towing. I kept it at 55 MPH on the highways and averaged something like 17.6 MPG on the way up and 20.2 MPG on the way back. I had anticipated 15 MPG overall.
I cant think of the part number off the top of my head right now but alot of times when I get a transmission from Jasper, they send me a Hayden transmission cooler kit for a Class A RV. They sent me one for an RX300 I did and last week I had to put a transmission in an Odyssey that also came with that kit. Its a quality cooler, probably a little overkill but its better to be on the safe side.
Thanks, love getting this kind of info.
So, no idiot light at 240 degrees, good to know. Now, it would really be interesting to know where the idiot light comes on. :bigok:
This is science, dammit!
Would you like to submit your vehicle for study “in the name of science”? Applications welcome! I’ve got plenty of hills I could test it against! My guess is that the light would come on in the 275 degree range. Perhaps my factory service manual would have this info in it?
I’ve ordered the B&M 70264 cooler and will install it prior to my next towing and off-road adventure coming up in July. This trip will take me up two significant grades (Sherwin Grade climbs to 7000’ and Conway Summit at 8100’) on HWY 395 and then on trails to about 8800’ all during the time of year we experience the hottest temps so the air will be at its thinnest and the air conditioning will be working its hardest. If I can navigate these climbs without baking my transmission then I should be good to go in most any situation I can think of.
That's only like a 3% temperature variance, 235 to 242. The trans temp is one of the inputs to the ECU and is one factor used to control how aggressively the converter locks.
-E
-E
3% of what? Usually we would use something other than just the ratio of degrees in Fahrenheit one to another since the units not based on a relevant baseline (0 is lowest temp you can get ice, water and salt in the case of Fahrenheit). I would probably go with the nominal temp of 180 degrees F in which case the difference is 62 and 55 degrees from nominal or about 13% which is significant, especially when the trend of the upper number in 4HI was to continue rising while the lower number was steady.
TC doesn't lock in gears 1-3, only 4-5. When in 4LO I believe only gears 1-4 are active and 5th is locked out from use. I believe I was in 4th gear when in 4LO but I could not detect the TC locking up in the way you notice it in 2HI. At any rate, temps continued to climb in 4HI while in 4LO they dropped back a bit and stabilized. 4LO it was for me!
Reading it makes me wonder if I should cover my oil cooler during winter, the oil temp is way below 150 when below 32F.
Your cooler should just bypass during the cold months.
This is what B&M claims with their coolers. Remember that if your engine coolant isn't completely reaching operating temp then your transmission will not either since the transmission fluid is pumped through the core of the radiator. If you are having issues getting things up to temp in the winter (not short trips but 30 minutes of driving or longer after everything should have had plenty of time to warm up) you would probably need to block of a section of the radiator to get the rise you're looking for.
By the way, my cooler arrived yesterday but the bracket on one side was bent up to 45 degrees from where it should have been and one of the two fluid ports was tweeked. There was minor damage on the external and internal box but nothing that should have resulted in this so I suspect it was damaged at some point before packaging, or at least the packaging I received. Good news is that a replacement shold be here tomorrow or Saturday so I can hopefully install this weekend. If the trans fluid appears to be spent I'll do a complete drain, pan removal, filter change and flush but I'd like to leave it so this way the only thing that will have changed for my next towing and off-road expedition will be the cooler so I can get a true read on how much of an improvement the cooler offers.
Does anyone know off hand which fluid hose is the return line for the transmission? There's an upper and lower hose that enter on the driver side of the radiator. My guess is that the upper would be the return but if I spent some time I can figure it out. I was just curious if anyone knew off hand.
Thanks.
Thanks.
Ill look tonight and be sure, but I think it was the bottom.
--edit--
I'm in a 5th Gen so nevermind
I tried to check on my '03, but because the two lines pass directly under the radiator, I couldn't be sure. But, depending on the size of the cooler you got, and where you intend to mount it, accessing the return line from the radiator might be easier on the passenger side of the radiator instead of the drivers side. I could only mount my Hayden cooler on the passenger side of the radiator, in front of the condensor, because of its size. My haden 243012 is over 11" square, and wouldn't fit in the same place as the V8 oem unit. So when mounting it where I did, it was much easier to access the return line (which is the lower of the two lines) where they emerge on the passenger side of the engine. I passed the two rubber lines under the radiator support and spliced into the return line to the trans. I used two pieces of larger hose to surround and protect the two rubber lines from any chaffing when they passed under the radiator and into the engine compartment. I have had the cooler in for over three years, and no problems. Good luck with yours.
Do we know exactly where the temp sensor is for the trans fluid?
I finally got my Scanguage ii installed and am curious, as there is a significant difference in what temp you should monitor/look for depending on this. For instance, measuring in the pan vs. the outlet from the torque converter.
Looking right now in the electronic FSM and I've found the two sensors on the diagram but I can't gather what exactly they are located on. When I install the cooler today or this week I'll decide if I want to do a fluid change. If I do a change then I'll replace the filter and should hopefully get to know this transmission better in the process.
On a good note I did discover that the outlet from the transmission to the radiator is the upper of the two lines where they exit the transmission.
Forgot to mention: I suspect the temp sensor that reads out is not sensing pan temp due to the fact that the temp climbs within a second or two after the torque converter unlocks once things are up to temp. I don't see how it could affect the entire pan temp that quickly.
Bottom was indeed the hot for mine. So from the bottom into the radiator, radiator to cooler, cooler back to transmission.
Here is a link to a 5th gen install.
http://www.toyota-4runner.org/5th-gen-t4rs/83227-transmission-cooler-2.html#post744021
Makes sense. In reading the reviews for the B&M cooler at Amazon the guys there were pretty insistent that trans fluid should flow anything from horizontal to upwards (never downwards in any way) through the cooler so as not to hold air bubbles in the system.
I agree with you here. It seems like it can't be the pan temp. I noticed the quick increases in temp as well when the torque converter unlocks. I hit 203 on the way home from work in extreme stop n go driving, but it cools quickly. Also noticed yesterday on the highway that as long as the converter is locked, and it seems to be almost exactly 90 degrees above the current ambient temp outside. It will quickly rise with unlocking and quickly drop after as well.
youngrk
