transponder key (I've done the search)
02runner4
sorry if this is a frequently occuring topic here. I've used the search box but I still need help.
I recently bought a 2002 4runner limited, but I was given only a key(master) and a remote. I bought a remote on ebay and I did the programming myself. Since I wanted to have more than one key, I bought two transponder keys on ebay. They look exactly like OEM ones. I followed the instruction below but it was not successful. The security light keeps blinking and it never stops. It seems like 2002 4runner transponder keys are programmable without going to the dealer and 2003 and forward can only be done at the dealer. I made an appointment with a dealer for tomorrow and they want to charge me about 50 dollars to program the keys. I still want to do this successfully without paying 50 dollars. The other dealer I went today quoted 120 dollars. He said it takes about 90 mins, and I told him about the other dealer that would charge me 50 dollars, but he said it's 120 dollars at his dealer, and that's based on standard labor charge.
Once I get transponder key stuff done and have my registrations and all, I will share with you guys about my car buying experience, hopefully within two weeks.
1. Simultaneously depress and release brake and accelerator pedals 1 time
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
After step 5 keep your key in the ignition, your blinking security light should turn off after about 1 1/2 minutes.
1 1/2 minutes.
Close, amended below:
All doors must be closed.
2. Insert existing master key into ignition. Turn Key to On position.
5. Within 10 seconds insert new key into ignition Turn Key to On position..
I tried that too, but did not work.
I went to a local Home Depot, and my master key indicated "fixed code," whereas brand new toyota transponder keys that I bought indicated "encrypted."
so I went to a dealer, but the dealer could not figure out. I was still charged 50 dollars, which I thought BS. They said they tried so ... what can I say... They made me wait two hours and 30 minutes and I finally saw the service guy but he told me to see the other person and told me he was looking for me a long time ago, which I thought BS. First they told me, I would not be charged again if I was going to bring back another set of keys, but changed their mind saying that 50 dollars would be applied back to 350 diagnostic fees that has to do with on board computer. I was thinking they wanted to clear all the codes on the computer and go from there, but when I asked what happens if they still cannot program after paying 300 dollars, they did not give me a clear answer. I do not think that I'm going back to that dealer again. They sell a gallon of toyota antifreeze for 28 dollars. The only reason I went there was because the labor fee was 50 dollars for both keys, wheares other places close to my house would charge 120 dollars.
I had to go to the other dealer very far and I finally got two more master keys, $171 including labor.
I sent back the keys that I bought online to the seller and I expect to get a full refund.
Deelock
