Trd bilstein lift spacer
Ricky_Medina
Does anyone have the dimensions of the lift spacer for the TRD Bilstein? I want to turn/ mill my own set during my machining class and have prints for future use. I would just take measurements myself but don't have time at home with a newborn. Thanks in advance.
Sent from my 2PS64 using Tapatalk
Are you referring to the toytec spacer?
There are two different ones. There is one that goes on the bottom of the shock mount. You should be able to use the stock collar to get the original dimension changing the depth of the collar giving you the spacer type lift you are seeking.
The kit from Toytec also has a spacer that goes on top of the shock as well. It would also need extended bolts to mount the shock to the vehicle giving you approximately and extra 1/2 inch in lift.
Lil Chap
