TRD Pro Wheels - biggest tire size
flynnstone
I’m buying a 2022 ORP, and the owner added the 17” TRD pro wheels. What is the biggest tire which will fit without lifting, or with a 2” lift?
i got 265s falkens wildpeaks and they fit closer to 275s alot more square
and they are 2mm away from touching the front and rear at full turns.. you cant go bigger than 275s it will rub
I’m running 285s on my Pro rims. With aftermarket UCAs on a 2.5” lift, we dialed up about 4* of caster and have no rubbing issues.
Same setup here for me. Currently 285/70 tire, but I’m planning to run 285/75 next, which is close to a 34”.
Jhunt
