TRD Pro Wheels on Stock Tires
Has anyone upgraded their SR5 wheels and had any luck selling the stock ones? I just put the TRD Pro wheels on my rig and not sure what to do with the old ones. I'd like to get something for them but am curious if anyone had any luck selling them and if so, for how much roughly?
List on Craigslist for $375ish. I sold mine in 1 day I think.
I don't think it looked too bad, as long as you didn't have a big lift. Here's mine with Bilstein 5100 all around with the front set at .85. Like others though, I didn't really care for the stock tires, and ended up swapping them for NITTO Terra Grapplers that a friend hooked me up with which made it look even better.
First picture is with the stock Dunlop, second is with NITTO tires.
I just picked up a low mileage silver 2018 SR5 Premium and want to do some mods. TRD pro wheels, these tires above (the Nitto Terra Grapplers) and a few other bits & pieces. Any suggestions on lift kit/suspension options? I am not going rock crawling but will be on dirt/farm tracks and some off road areas. I'm not very price sensitive but I don't want to spend money on stuff I don't need. Thanks for your help!
Anomalous, like your rig. Mine might end up just like it. Two questions:
1) How do you like the front leveled at 0.85"? I'm going to put on 5100s, but thinking of going a bit higher, plus rear 5100s with a little spacer. Did you consider doing anything in the rear?
2) I can't decided between gray and black TRD wheels. Hard to tell from pictures. Yours looks nice, I presume that's the gray?
I lasted 500 miles before I had to change em out. I was going to go KO2's as I had them before but got a killer deal on the Ridge Grapplers. I struggled a little to sell the stock tires, finally got rid of em at $300, but since the Nitto's were only about $600 installed I didn't mind the loss as much.
IMG_20190831_035325 by Michael Starmer, on Flickr
Hey, thanks! I like it at .85 with the stock tire size, but would consider going a little higher if I go with bigger tires. Main thing for me was to be able to keep alignment within spec. From what it looked like when I went for alignment, it was maxed out at the current setting, so if I go any higher, I would also look at aftermarket suspension parts. In that picture I had the gray TRD wheels. I swapped them out for FN wheels not long after
