TRD Skidplate Question
Nick B
Member
Are there 2 different TRD skid plates for the 4Runner ? On EBay they show one for one up to 2023 and then another one for 2024 with almost a 100 dollar difference in price . I’m looking for one for a 2024 OR .
The regular skid plate does not fit 4Runners with KDSS. Thus the one for '24 may be with KDSS and the other without KDSS.
TRD skid plate there are two variations, one that with TRD stamped and the other with plastic TRD snapping into place. Either one will fit any model besides KDSS equipped models.
The part number for the TRD front skid plate for 4Runners that do not have the KDSS option is PTR6089190.
This skid plate is not applicable to vehicles with KDSS (Kinetic Dynamic Suspension System).
Confirm which suspension you have before ordering.
Some links that show that this skid plate will fit 2024 OR 4Runners.
2019-2024 Toyota 4Runner TRD Skid Plate-4Runner PTR60-89190 | TRDToyotapar
PTR60-89190 - Skid Plate, Front, Trd 2019-2024 Toyota 4Runner | Longo Toyota Parts
PTR60-89190 - TRD Stamped Aluminum Front Skid Plate - 2019-2024 Toyota 4Runner | Sparks Parts
First time posting and I have a question.
1st time changing oil in our 2019 TRD Pro we got a few months ago, I noticed a missing bolt in the skid plate. I found a bolt that would fit but also found the threads were F'd about halfway through. So I bought OEM replacement bolts and a tap, but the replacement bolt kit came with a couple of spacers. I don't think the stock TRD Pro needs the spacers as they would be for other non TRD Pro trims. Can someone confirm? Thanks in advance.
[MENTION=793512]Tucker556[/MENTION]
TRD Skid plates come with 2 short bolts (rear) and 2 longer bolts with spacers (front).
That is normal for any 2010-2025 4Runner other than limiteds and special versions.
The spacers (round aluminum spacers) locate the bolts into the front radiator support brackets.
Hope this helps.
I have a mod that replaces the bolt up skid with studs and it makes the process easier and stops stripped threads!
TRD Skid Plate Mounted w/ Studs 2010-2025
