TRD Wheels - differences of bronze 40th anniversary PTR56 vs PTR20? More info. below.
bandit350
Junior Member
2005 V8 Sport in silver. I'm working w/ a local shop on replacing the XREAS suspension, adding a small lift, getting new bronze wheels, and tires. I reached out to FN Wheels but didn't hear back and it looks like their bronze wheels aren't an option at this time. From searching on here the wheels will fit my vehicle.
I can't seem to find the differences between these two wheels:
PTR20-35110-F5, 17" diameter, 7" width, 4mm offset, bolt circle 6 on 139.7mm, TRD center cap, flat finish, TRD logo on center cap.
Currently showing $299 on Toyota's website.
PTR56-89210-F5, 40th anniversary wheels, 17" diameter, 7" width, 4mm offset, bolt circle 6 on 139.7mm, flat finish.
Does this need a separate center cap? I came across PT998-35221-5F on the website for $14/ea.
Currently showing $245 on Toyota's website.
I reached out to my 2 local dealerships and never heard back. It appears that both options are available. Any insight on what I'm missing regarding differences, fit, finish? Where would you recommend ordering from? BAM wholesale, a random dealership, a local dealership?
PTR20 is the bronze TRD rim ("TRD" Center cap)
PTR56 is the bronze anniversary edition ("Toyota" Center cap)
I believe both rims are the same in all other aspects except color. TRD is a brighter bronze, the Anniversary is a more muted bronze.
bluelinepilot
