Tricky Transmission, Need a Shifting Solution.
TX_QtPi
Okay Guys so we got a real Conundrum...
I have a 1991 Runner 4x4 with a 3.Slow and a 5-Speed Manual transmission.
Was out driving and the pedal adjuster linkage fell off (came unscrewed from the linkage).
the pedal went to the floor and it would NOT shift gears. Got a new Master and a Slave, and Bled the crap out of it! My "mechanic" even went as far as putting it on some vacuum machine that pulls the air out of it and it still would NOT shift.
He recommended (or diagnosed it) as being the clutch plate. So New, clutch kit was installed. STILL WILL NOT SHIFT!!!
If the truck is off it shifts through all gears just fine, but turning the engine on will make the shifter NOT go in any of the forward gears and only grind in reverse.
If I start it with the transmission engaged in 1st gear, it will leap (lunge) forward and if I keep it going it will shift up while driving at the shift points.
I'm guessing maybe he knocked loose the vacuum line and put it back in the wrong spot or maybe something else has gone wrong.
He's trying to talk me into a $1,600 rebuild BUT although I love My Runner, I'm NOT wanting to dump that much into a 1991.
Any ideas what the solution might actually be? After him telling me straight up he doesn't know what's wrong with it and misdiagnosing it as a clutch I've lost faith in him.
I really think him telling me a rebuild is the answer is a scape goat to something else, particularly since he said, "it might be the synchros (sp?) OR maybe a bent fork, or something else" um... dang it man, you're the transmission guy, you're supposed to know!! :rockthrow:
PLEASE Help!! I don't want to get rid of her but I'm NOT at the point of dropping $1,600 into her either.
Thanks Y'all,
Cynthia
Sounds like the clutch isnt getting enough throw. Maybe if you adjust the linkage on the back of the pedal it will work.
From your story, it seems that you could have just re attached the linkage and been fine?
I also think you need a new mechanic...
He CLAIMS he adjusted the pedal. :shrug:
I'm thinking you are right on the new mechanic.
Thinking of pulling it out the shop there and bringing her home at the least.
OR finding a new trans-shop that can actually figure this out.
Hope a solution can be found
check the peddle adjustment, do it a little at a time. and make sure your floor mat isn't blocking the peddle.
have someone push the peddle and look at the slave cylinder move, if it gets a complete stroke or not.
a simple bleed is all that is needed, if he charged you for that vac/purge hippy crap, get your money back.
I'm no help on the fixing it part, but I just want to say that if it is a bad trans somehow, a $1600 rebuild is retarded. $200-$300 for a junkyard trans and just keep driving.
i actually had this same prob with my 91 that is my daily driver when i got after doing the clutch and all the hydraulics it was my actual clutch peddle assy that was broke
charlesz
