Trifecta Build Thread - KOH EMC, Cruise Moab, Rubithon
This will be badass. Would love to see that front diff in there. Please swap to at least 37's when wheeling in Moab or Rubicon.
I'm questioning the aluminum bumpers. Just not sure how long they will last, and not sure if you can make the rear bumper strong enough out of aluminum with a tire swingout.
Thanks - I've already got the 37s in the basement now! We'll see how much they might rub in the rear...
I did some reasearch on Aluminum vs. Steel Bumpers and everything I saw said Aluminum is As Strong as steel, but maybe the durability after a ton of abuse could become an issue. And obviously weight savings is huge on bumpers, so I'm torn.
Note, no need for a swingout tire carrier - the spare will be mounted in the cargo area (or it would literally be torn off at KOH coming down a ledge :)).
Whichever type of spindle you go with, a 0 offset wheel is about as close as you can get to the aftermarket spindles (depends on the wheel width too I guess). Not sure about the weld-on gussets. If you can, try and find beadlocks that run as close as possible to the spindle to keep your width down. You will keep the same amount of travel while not being so wide.
05'-09' are the years they had the vvti V8 motors, not sure why you list 06'-09'.
Good to know. The wheels will likely be 17x9.5. I'll aim for 0 offset. What about backspacing?
And I know the '06 has a few nicer upgrades (headlights, etc) simply for cosmetic purposes. If we're going to have a lot of sponsor names on this rig, it better look good before the race for pics :). I'm completely open to the right '05 though!
If you are looking into weight savings here is the list I have made w/ #'s. I've been looking into lightening up my truck where possible.
-They make 2" solid aluminum suspension links threaded on both ends for joints. If you do the math vs 2x.25 steel tubing you save like 20lbs or so with a long 4-link setup (unsprung mass). Just as strong more or less and some race buggies/trucks are running them. Couple hundred $ more. Heat treated 4140 Chromoly tubing would be the lightest but most $.
-I'm looking into 1/8" AR400 skids for mine. My 3/16" steel skids are 115lbs. 1/8" steel are 81lbs, and 1/4" aluminum is 60lbs for the set of 3. The AR400 skids would be as strong as 3/16" steel skids, stupid hard so they slide over rocks really easily which aluminum doesn't. Nobody makes AR400 skids so they would need to be custom made.
Extremely helpful! Weight savings with added strength!
-Racing seats I'm guessing are lighter than stock. Of course you could probably get rid of the rear seats and passenger front seat for racing.
-Fiberglass fenders are lighter. They make fiberglass hoods for Tacomas but not 4Runners as far as I know. They won't fit ours unless you swap headlights/ grilles/ and fenders with them (is possible).
-Remove factory roof rack and towing accessory. Have receiver tube integrated into rear bumper. Remove spare tire winch (that thing is heavy!)
-Fuel cells will be lighter of course, since they carry less fuel and need a smaller or no skid plate depending on location. Gas weighs 6.2lbs/gallon.
[/INDENT]
Pro suspension racing seats will be installed and the rear seat will be removed for KOH EMC.
Fiberglass fenders will be added. The fiberglass hood probably isn't worth it.
Fuel cell will be added and no skid needed since it'll be in the cargo area.
All great feedback and suggestions - keep 'em coming!
Link 1
Link 2
Great thread and great ideas on weight reduction above! A few notes on the KoH EMC Stock Class Rules and front differential IFS options that I looked into before.
IFS Front Differential Options
The Currie unit is a good one but don't rule out other options depending on how you wanted to package things (centered versus offset):
- The Spidertrax front chunk - set up as a centered diff, like the Currie F9, unless you make a custom tube to run it in an offset location
- The Dynatrac XD60 IFS differential set up for GM 2500 trucks (this has an extended axle tube option if you wanted to keep the drivetrain changes simple by keeping an offset differential versus a centered unit). The Dynatrac unit is stout but it will weigh more than a fabricated housing from Currie or Spidertrax
- A factory GM 2500 IFS differential - not as strong as the above but you have a larger ring gear than the Toyota and they are pretty inexpensive. Once upon a time Tim Lund (top IFS builder) was looking at a budget IFS option based off of the GM2500 differential. I don't think he ever released that but you could always chase him down to find out.
Steering
- Someone else may have mentioned it but try giving Howe a call to see what they can do with the Toyota box (or retrofitting a box from a larger IFS truck, such as a Chevrolet/GM 2500).
- Solo - I didn't realize they had a solution but the Tundra box sounds interesting.
A few extra thoughts on weight reduction
- Hoods - atleast in 2014/2015 fiberglass hoods were not allowed for stock class vehicles (fiberglass fenders were okay but I don't think too many people ran them).
- Doors and hatch - You could gut your doors leaving just the outer skin plus a minimal tube frame to allow it to open and close. It varies from truck to truck but this should allow you to drop some significant weight. For the 4runner you could do the same for the rear door.
- Aluminum control arms may not be the lightest depending on the diameter but you can use a smaller diameter upper link to shave a few pounds and 7075 aluminum is stout.
I looked into a similar build for KoH using either a 4th Gen 4Runner or a WK2 Grand Cherokee. I ruled out the WK2 because of the unibody, lack of any serious suspension development in the aftermarket, and lack of gear or locker options without swapping both the front and rear ends out for F9 or Spidertrax axles. The V8 4Runner may be down on power to the WK or WK2 but you have a V8, a nice wheelbase, a nice rear suspension setup to work with (versus leafs on a truck), and great suspension options from quality companies. Total Chaos, Camburg and Solo have already done the engineering AND testing on the 4Runner suspension - in my humble opinion that is one of the biggest challenges to build a competitive truck. Other than the cage which would probably need to be custom, if Solo has a solution for your on steering, I think you could build a competitive rig with 'mostly' bolt on, or at least prefabricated parts for the 4Runner.
I hope someone goes ahead with this for 2019!!!
I sure hope this build gets off the ground! A lot of the things discussed in here are some of the things I’ve been wanting to do to my 4th gen just to take it to the next level. I’d absolutely love a shot at the KOH course and the hardcore trails in Moab and around the SW in general but I would probably have to build a more dedicated buggy to make it survive what I’m envisioning. Plus, I’ll admit it, I’m a little attached to my 4th gen so I don’t exactly want to destroy it. Maybe I could pick up another 4th gen to “play” with.
Again, I sure hope this build gets going as I love seeing built up 4th gens and seeing people actually use them.
I'm excited to say that this Steel City Racing: King of the Hammers 2019 Toyota 4Runner IFS 4600 Build has officially commenced! Thank you to everyone who contributed to this post - it laid the ground work of what is going to be an awesome build and an amazing adventure.
Follow our progress on Instagram and Facebook:
Facebook: https://www.facebook.com/SteelCityRacing4x4/
Instagram: https://www.instagram.com/steelcityracing4x4/
And check out the official build thread here:
http://www.toyota-4runner.org/4th-g...019-toyota-4runner-ifs-4600-build-thread.html
