Trim and rack paint
Majindan
What kind of paint is best for durability besides bedliner spray? I need to sand and spray the ski racks and other black areas on my steps and bumper. Just several coats of black trim paint? I just don't see that lasting.
I tried that and did not like the results. It was real pain to strip down the tracks. I finally took it to powerdercoating place and got back something that looked brand new, Be aware that if you remove the tracks from the roof - there is a set of gaskets between the screw holes and the the roof top. These gaskets are no longer avaialble per the dealer. I used some rubber washers from Lowes and silicon rubber
Be aware that if you remove the tracks from the roof - there is a set of gaskets between the screw holes and the the roof top. These gaskets are no longer available per the dealer. I used some rubber washers from Lowes and silicon rubber
do you happen to have any photos of exactly what you used?
Thanks for the heads up about the gaskets, what a PITA.
*edit* I am just going to use bedliner spray lol.
I used Rustoleum high performance enamel spray paint. It's the taller , silver cans at Lowes. Did my rack and spoiler, and my wife's rack. It's held up great a year later. Sand any loose or flaking paint, the a coat of primer. Three light oats of black and you're good to go.
I didn't have any gaskets on ours. When I reattached, I dropped some silicone in the holes before I screwed them ack in. No leaks!
http://www.rustoleum.com/en/product...ds/professional/high-performance-enamel-spray
Professional High Performance Enamel Spray Product Page
I used that on my wiper arms. It has held up great. Did you notice that it takes FOREVER to dry?
Not without taking off the rack :)
Lowes has a selection of odd bolts, screws washers etc... They are all in slide out drawers. I found rubber washers about 3/4 in diameter with a hole of about 1/2 inch. Imagine a washer for the garden hose but about 1/3 the thickness and about 75% of the size. I glued them to the bottom of the metal frame with silicon rubber and then coated the side of the washer that would rest on the roof with the same. Also ran a bead around the screw to make sure water didn't get in the screw holes. No idea why Toyota quit selling these washers - they still sell other parts of the rack like the end caps
Lowes has a selection of odd bolts, screws washers etc... They are all in slide out drawers. I found rubber washers about 3/4" diameter with a hole of about 1/2". Imagine a washer for the garden hose, but about 1/3 the thickness and about 75% of the size. I glued them to the bottom of the metal frame with silicon rubber and then coated the side of the washer that would rest on the roof with the same. Also ran a bead around the screw to make sure water didn't get in the screw holes.
thanks for the tips!
