Trouble programming new remote key – suggestions?
eric_rosenwald
I recently bought a remote key for my 2000 T4R. I bought the correct model, and I memorized the programming instructions.
The problem is that I can't get into programming mode in the first place. When I go through the 5 cycles (1 cycle is a lock and unlock) of the driver door lock rocker, after 2 cycles, the driver door stops locking/unlocking. I've continued with the instructions, but it still doesn't work.
I can explain it, but it's easier to see my video for the problem:
https://youtu.be/yU0LdfpQYGY
Thanks for your suggestions
I had the exact same issue. You can get it to work by 'helping' the lock solenoid on each lock/unlock. I pushed down/pulled up on the plastic lock thingie in time with me cycling the lock switch. It may take a few tries to get the timing down, but this definitely worked for me. It was suggested on another thread that I found when I had the issue.
It took me like 3 days to get my truck in program mode. I did the cycling the lock thing really fast on the one time I got it into programming mode
Thanks. I'll try it out later today
By the way, I will never stop loving the millennium silver paint. Cool to see you've got one too!
