Trouble with exhaust
Cmwise
I got a 90 3.0 and I am doin a head gasket replacement on and I am having trouble getting the exhaust off. Is there any tricks? I got a lot of the bolts/ nuts off mainly the top and front ones but can't get to back bottom ones really. Any advice would be great
Go to Home Depot (or the like/similar) and purchase a Map Gas Torch(not propane). They are usually about $40. Just be exceedingly careful in where, and how you point/use it! You might consider installing a header(NWOR or the like) if your going to that level of repair.
With the torch, you can heat the hardware up to where it is almost red, or changing color and usually, it will roll right off. If it starts to bind, reheat it again. When your torching things, try to only hit with the flame and heat, what you want to remove itself (ie only the hardware, not an alu head, or sensor/wiring, etc....). Otherwise, you might end up damaging something else in the process. Best of luck with it.
regards
Thanks for the input I will definitely try that method. But I was more or less wondering how to get to the bolts since there's not a lot of room
For some, I go in from the wheel wells. It's tight, but doable. You might consider using copper anti-seize on the exhaust hardware when putting the stuff back together. It will make your life soooo much easier the next time you have to go in there. You'll find with the intake removed, there is a lot more access towards the back of the heads (ie cross pipe, etc...).
regards
I feel your pain since I did this a few days ago. You can get to the drivers side nuts from below the vehicle with extensions and a wobble. They will be locked on very tight but you won't lose as much skin off of your nuckles if you go this way.
charlesz
