Truck Norris
Hey just a little advice from a guy who is already $8-9000 into an overlanding build, forget the 35s for now until you get some key things. In order to get you r front end high enough to fit the 35s you will need aftermarket front upper control arms and a lift that uses longer springs rather than spacers. The toytec ultimate is good, make sure you get the heavy weight coils if you plan on getting that 3 hoop bumper otherwise it will sag. You will need the 1-1/4 body lift from 4crawler, you will need to do the "body mount chop" to keep the 35s from rubbing the mount at the rear of the front wheel well , and you will need wheels with different offset or spidertracks wheel spacers. You WILL need to regear your axles to comfortably drive it, even 33s makes the gearing a little screwy. If you are going to re gear that would be the time to install the locker too. This way you aren't spending money twice. Grab some 33s and make that work for now, hold off on those 35s until the truck is more built. If you have any questions feel free to PM me.
MaximussK
