I will keep this initial portion blunt. My truck was discharging the battery out of nowhere this weekend. 11.8v at idle, 11.8v with it off. Checked alternator an it passed, 3 times consecutive. Truck is still not charging.
-Checked ALL fuses, except main (150A?) alt fuse
-Only one light on dash, driver airbag light
-Signals not working on lever, but flash with hazards like normal
-Heater display is blank. It lights up, but no function/time/mpg display
-Ground is solid, no corrosion, cleaned all connections, tightened terminal
-Power is solid, just re-did all connections, no corrosion, wire is solid with no splices or damage.
Thoughts? Has anyone had this linked issue before? Google returned a few VERY similar symptoms, but each of them brought no follow up.
THOROUGH VERSION HERE;
Friday night I swapped head units. Kenwood for Kenwood dual din. Same harness, unplug and plugged in main harness, antenna, RCA's, ONLY thing different was a tap into power an ground on harness for backup camera. Installed, checked power WITH THE HEATER CONTROL unplugged. I suspected airbag light as a consequence. Said shit, put it together, started it, no lights period. Tuned new head unit, took it for a drive, all good, camera performs flawless.
Saturday morning I am going shooting, I get up, go get gas, then to Walmart for a pass, then to Cabelas for ammo, ect. I make 5 start and shut off cycles, no lights, nothing abnormal. 6th cycle we are leaving to shoot. 21 miles from home, I get the airbag light ONLY. I am not real shocked, an continue on. 5ish minutes later, the check engine light, VSC, traction control, e-brake light, ALL that crap comes on, but no battery light. I pull over an shut the truck off, everything working as normal. Windows, signals, radio, has power, ect. I look an see if anything catastrophic just happened, go to start the truck again and I get starter click click click. Go over wiring, another once over, check terminals, all seems fine. Start it, fires right up, slight hesitation after initial fire an idle stabilized after maybe 1 second but I noticed it. Start heading home, truck abruptly dies, no dimming of lights, no power loss, I was accelerating uphill prior for a good 1/2 mile, I'd have felt it. I let off at the top an dead.
Pull over, this time it never fired again. I am in the middle of nowhere essentially, after 5 hours no tow trucks will come, I finally get someone to rescue an bring a new battery an OBD reader if nothing else. Battery get's it going, ONE light remains only, the air bag light. All functions perform, signals, radio, power, traction control again. I drive the 30 minute trip home, check an 11.8v at idle and off with the brand new battery, signals stopped working, no heater control, no display for mpg, no new dash lights. Both batteries now, original and brand new read 11.8v. The new one just got me home.
So, test alternator, passes. Inspected wiring, checked all fuses except the main one under the fuse box, look for anything off, an here I am. Suggestions? Idiot proof test theories? I am very poor at electrical diagnostics. I learned to install stereo's proficiently and haven't ever gone much further. It's my least favorite an depth ability with mechanics, otherwise I can build about anything but never dabbled in electrical. So please consider that if there is something stupid I'm missing here.
