Trucks not starting.
zgensler31
Senior Member
So I get in. Turn the key. Everything's working as is til you get to start and then it cuts power off. Get out. Jiggle the terminal cables a little. It gets power back and same thing. I've pulled every fuse....battery isn't the greatest. Kind of old but tested it a few weeks back and it was an OK reading.
Could it just be the battery? Or relay or terminals? What is it? I've got a jump on the way.
Also just heard a faint clicking coming from the dash area? Seems like its right behind the vents?
Sounds like your battery is drained. Your starter is trying to engage and start, but not enough current to do so. If you drive around and recharge the battery, but find yourself not being able to start your 4runner again, it might be a bad battery.
DJNutshell
