True Flow "XDI" (CAI) Kit 4.0L V6
The thing to look at is the total miles on your odomoter until you get close to empty. I'm pretty sure his final # went up quite a bit with this installed.
Don't know if I like my XDI...
So I too installed the True Flow XDI canister in my '04 V6. I have to say, as far as Aftermarket parts go, this one is very well made, packaged, good directions, etc. It took me about 45 minutes to install the kit.
Interestingly enough, as soon as I started my car, (with a full tank of gas) my trip computer said I had a range of 385 miles, and it's never said any more than 350. I know this isn't exactly very accurate, but I found it interesting.
I then ran the car around my block. There is definitely a better deeper growl to the motor. However, when I hit WOT and the car spooled up from about 3500rpm to 5000, there is a HORRIBLE vibration and resonance from the airflow. I called True Flow, they were helpful up until the point they came back and said the tech said "for some reason, Toyota's are just loud..." OK... Well, I do notice a nice boost and from 3 tanks now, better gas milage, by 8-10% per tank.
I might actually put my stock back on, just because this thing is LOUD at WOT. Anyone else experiencing the same thing? Let me know.
WOT...What?
You never gun the the throttle to accelerate past moronic traffic, getting on a freeway, passing? :confused:
These are just some of the reasons I hit WOT :p
most CAI's return about 1-2mpg better by reducing pumping losses and increasing flow...so 24 seems a bit high but i have no doubt that 22-23 is reasonable.
Since purchasing my Volant from Jason, I consistantly see about 2mpg better and if I get the wild hair to really try and get better gas mileage, I can see nearly 4mpg.
Derlowe i have the results as you...after 6 months its getting annoying and mpg's are not better...power is there after 2500 rpm and seem to have lost some low end hp and torque and gained some low end growl that is annoying. Maybe TRD cai is a better fit for the 4.0 V-6. Hope this info helps.
