TSB's for 2004 4Runner
cardriver
Hi all,
I've accessed the info for the V6 '04 4Runner at alldata.com but this list is worthless because I can't access any additional information pertaining to which vehicles these pertain to. (i.e. VIN , build date, etc.) Here's what I found
TSB Number Issue Date TSB Title
1. DL001R-04 MAY 04 4WD System - ECU Service Precautions
2. BO005R-04 APR 04 Body - Windshield Molding Deformed/Warped
3. BO007-04 APR 04 Interior - Front Seat Track Cover Removal
4. NV003-04 MAR 04 Interior - 2nd Row Passenger Side Seat Noise
5. PG001-04 MAR 04 Direct Tire Pressure Warning System - Diagnostics
6. EL003-04 MAR 04 Electrical - 'Crank Hold System' Jump Starting
7. BO017R-03 MAR 04 Interior - Trim Panels Loose/Fit Poorly
8. BR001-04 FEB 04 Brakes/Traction Control - Zero Point Calibration
9. EG020-03 DEC 03 Emissions - MIL ON/DTC's P0441, P0442/P0446 Set
10. PG009R-03 DEC 03 Tires - Inflation Pressure Adjustment With TPMS
11. SS004R-01 SEP 03 Engine Controls - Error When Reprogramming ECU
12. SS002R-01 SEP 03 Engine Controls - ECU Reprogramming Procedure
13. TC005-03 AUG 03 A/T - A750E/A750F Fluid Level Checking Discontinued
14. PG005-03 AUG 03 Wheels/Tires - Spare Tire Carrier Operation
15. SS003R-02 JUN 03 Antitheft - Diagnostic Tester Immobilizer Functions
Does anyone have any additional info on these available somewhere?
Also, if some of these pertain to my vehicle, do I just take it to the dealer and have them check out say # 4? (Sorry for the noob response)
thanks for your help
CD
Most of those look to be service procedure updates, and not actually problems with the vehicle.
If #4 is what you are after, just unlatch the seat and wrap a couple wraps (about 2) of electrical tape around the latch striker (u-shaped loop) that is mounted to the body. That fixed the problem, and saved me a trip to the dealer for a two minute fix.
I like to avoid the dealer trips unless it's major stuff, and then I usually have them apply any TSB's or recalls at the same time.
--Mike
Just trying to keep tabs on any issues going on. I agree about the dealer contacting you. I used to own an Acura and they sent me info regarding a catalytic converter issue replaced. Thanks for the info
CD
--Mike
I dropped my 04 4Runner off at the dealer this AM for the sulphur TSB. He said he would pull up any TSBs.
Well, he called me and said nothing came up. After I faxed a copy of the TSB he changed his tune and ordered the parts.
I am saying this to point out that the dealer may not necessarily own up to the fact that TSBs are out there for your vehicle. My service guy told me that they would use the TSBs to fix any REPORTED problems.
What I really would like is a place to access the actual TSB document, because that is the only thing some dealers will honor.
Do a search, as several of the TSB's have been posted here in the past.
Then visit techinfo.toyota.com and sign up for a 1 day subscription ($10). This will give you access to PDFs of all TSB's, Service Manuals, and electrical manuals.
Too bad you were not here a week ago when I had made a post offering to look up tsb's for anyone that needed them before my subscription ran out.
That's just my luck!
Thanks for the info. I have run several searches and only was able to find one TSB doc.
Was just doing a search on the TSB's for my 04 and thought I would post the new list. It has grown a little. :)
Service Bulletins
TSB Number & Issue Date TSB Title
EL003-05 MAR 05 Instruments - No Image Displayed From Back-Up Camera
EG014-05 MAR 05 Cooling System - Radiator Cap Inspection Procedure
BO001-05 JAN 05 Body - Moonroof Parts Replacement Procedures
PG001R-04 JAN 05 Direct Tire Pressure Monitoring System - Information
EG048R-04 JAN 05 Emissions - LEVII EVAP System Check for Multiple DTC's
TC002R-03 DEC 04 Engine/Transmission Controls - Resetting ECM Memory
AC009-04 DEC 04 A/C - Sensor Inspection Procedures
TC009-04 DEC 04 A/T - A340 Solenoid Identification
BO022-04 DEC 04 Restraint System - Seat Belt Extender Availability
TC006R-03 DEC 04 A/T - New Fluid Introduction/Compatibility
BO010R-04 OCT 04 Interior - Rear Seat Arm Rest Cup Holder Replacement
NV013R-03 SEP 04 Body - Moonroof (Sliding Roof) Rattles
EG037-04 SEP 04 Engine Controls - Bank 1 & Bank 2 A/F & O2 Sensor ID
EL009-04 AUG 04 Electrical - Power Window/Roof Initialization Procedure
BO013-04 JUN 04 Interior - Accidental Seat Adjustment Handle Contact
EG021-04 JUN 04 Recall - Excessive Exhaust Sulphur Odor
EG020-04 JUN 04 Recall - Excessive Tailpipe Sulphur Odor
BR001-04 FEB 04 Brakes/Traction Control - Zero Point calibration
TC006R-03 DEC 03 A/T - Type WS Fluid Service Precautions/Identification
tuṣṭāva
