TSB's
owen4runner
I was just browsing the ALLDATADIY.com website and came upon all these TSB's for an '04 4Runner. Does anyone have copies of these TSBs or know where to get them? Unfortunately you have to subscribe to ALLDATA to be able to view them.
"Automotive Recall and Technical Service Bulletin Titles for 2004 Toyota Truck 4 Runner 2WD V6-4.0L (1GR-FE)."
TSB Number & Issue Date TSB Title
LSC40C MAY 04 Campaign - Engine Crankshaft Pulley/Seal Replacement
EG049-07 DEC 07 Engine - Oil Leak From The Timing Cover
PG008-07 NOV 07 Vehicle - Replacement Certification Labels
PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information
EL010R-07 NOV 07 Keyless Entry - Remote Transmitter Programming Guide
DL003-07 NOV 07 Drivetrain - Front/Rear Differential Oil Spec. Change
BO017-07 OCT 07 Restraints - Seat Belt Tongue Plate Stopper Service
PG005R-03 OCT 07 Wheels/Tires - Spare Tire Carrier Operation Information
SS006-07 AUG 07 Battery - Absorbed Glass Mat Battery (AGM) Information
SS004-07 AUG 07 Restraints - SRS Component Disposal
TC010-07 JUN 07 A/T - 'World Standard' Transmission Fluid Information
EG034-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor identification
AC002-07 MAY 07 A/C - Blower Motor Ice Build-Up
SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
NV003R-04 APR 07 Interior - 2nd Row R/H Seat Back Noise
ST005R-01 MAR 07 Steering/Suspension - Vehicle Pull Manual Supplement
TC003-07 MAR 07 Drivetrain - Driveshaft Replacement Precautions
AU001R-06 FEB 07 Audio System - Quick Reference Diagnostic Guide
EL003-07 FEB 07 Air Bag Systems - Repair Manual Supplement
EL006R-05 DEC 06 Charging System - 'Charge' Warning Lamp ON
PG001R-04 DEC 06 Direct Tire Pressure Monitoring System - Information
PG009R-03 DEC 06 Tires - Inflation Pressure Adjustment with TPMS
EL014-06 DEC 06 Daytime Running Lights - Deactivating
PG001R-06 NOV 06 Electrical - Battery Maintenance and Testing
PG004-06 NOV 06 Tires - Tire Pressure Warning System Diagnostic Tips
NV011-06 OCT 06 Interior - Driver's Seat Noise/Shifting Sensation
NV009-06 SEP 06 Body - Upper/Lower Windshield Ticking Noise
CRIB146 SEP 06 Body - Paintless Dent Repair Information
BO016R-06 AUG 06 Body - Moonroof Stuck/Improper Operation
NV005-06 JUN 06 Interior - Front Seat Track Squeaking Noise
PG011R-05 JUN 06 Fuel System - Fuel Injector Cleaning Procedure
EL006-06 MAY 06 Body Electrical - Erratic Back Door Functions
NV004-06 MAY 06 Interior - Front Seat Squeak Noise
EG029-05 MAY 06 Fuel System - MIL ON/DTC's Set/No Start in Extreme Cold
EG043R-05 MAY 06 Fuel System - MIL ON/DTC's/No Start in Extreme Cold
BO017R-03 APR 06 Body - Interior Trim Panels/Garnish Loose
BR004-06 MAR 06 Brakes - Inconsistent/Unusual Brake Pedal Feel
BR001R-04 MAR 06 ABS/TCS - Zero Point Calibration Procedure
PG010R-05 FEB 06 Tire Monitor System - Tire Dismounting Precautions
AU001R-05 FEB 06 Audio System - Amplifier Won't Turn OFF/Battery Drain
EL006R-05 JAN 06 Charging System - 'Charge' Warning Lamp ON
BO022R-04 DEC 05 Restraints - Seat Belt Extender Availability/Application
BO001R-05 NOV 05 Body - Sunroof Components and Service Procedures
SS003-05 NOV 05 Audio System - CD Player Skip Verification
BO014-05 NOV 05 SRS/Interior - Seat Cover Replacement Caution
PA002R-02 OCT 05 Paint - Paint Stains Under Rapgard
AC004R-05 SEP 05 A/C - Erratic Blower Motor Operation
ST001R-05 SEP 05 Steering - Highway Speed Steering 'Flutter'
SS003R-02 AUG 05 Antitheft - Diagnostic Tester Immobilizer Function
PG018R-02 AUG 05 Body - Power Window/Moonroof Initialization
EL011-05 JUN 05 A/C - Inoperative/A/C Light Flashing
EG045R-04 JUN 05 Engine Controls - Entering VIN When Replacing PCM/ECM
EL003-05 MAR 05 Instruments - No Image Displayed From Back-Up Camera
EG014-05 MAR 05 Cooling System - Radiator Cap Inspection Procedure
PA003R-02 FEB 05 Paint - Refinishing Bumper Cover
EG005-05 FEB 05 Engine Controls - MIL ON/DTC'S P0136/P0156 Set
EG048R-04 JAN 05 Emissions - LEVII EVAP System Check for Multiple DTC's
TC002R-03 DEC 04 Engine/Transmission Controls - Resetting ECM Memory
AC009-04 DEC 04 A/C - Sensor Inspection Procedures
PA005R-04 DEC 04 Paint - Iron Rust Contamination Repair
TC009-04 DEC 04 A/T - A340 Solenoid Identification
BO010R-04 OCT 04 Interior - Rear Seat Arm Rest Cup Holder Replacement
CRIB141 OCT 04 Paint - Chip Resistant Coatings
NV013R-03 SEP 04 Body - Moonroof (Sliding Roof) Rattles
EL009-04 AUG 04 Electrical - Power Window/Roof Initialization Procedure
BO013-04 JUN 04 Interior - Accidental Seat Adjustment Handle Contact
EG015-04 MAY 04 Exhaust System - Excessive Sulfur Dioxide Odors
BO005R-04 APR 04 Body - Windshield Molding Deformed/Warped
BO007-04 APR 04 Interior - Front Seat Track Cover Removal
EL003-04 MAR 04 Electrical - 'Crank Hold System' Jump Starting
SS004R-01 SEP 03 Engine Controls - Error When Reprogramming ECU
SS002R-01 SEP 03 Engine Controls - ECU Reprogramming Procedure
CRIB136 SEP 03 Body - Full Frame Components & Precautions
TC005-03 AUG 03 A/T - A750E/A750F Fluid Level Checking Discontinued
PA007-03 JUL 03 Paint - Body Trim & Cladding Colors
PA006-03 JUL 03 Paint - Paint Colors - All
CRIB127 MAY 03 Glass - Windshield and Fixed Glass Bonding
PA002-04 APR 03 Paint - Color, Scratch Resistant & Anti-Acid Paint
CRIB122 FEB 03 Body - Body Sectioning
The most interesting TSB's are floating around here. Do a search by the TSB number.
Many of those TSB's are informational in nature, and are not actually problems.
If you want to download all of them, you can sign up for a 1-day subscription to Toyota TIS ($10) and access Toyota's own site full of TSB's and manuals.
