Tundra Brake Upgrade Question
I have standard 5 spoke 16" wheels and I'm about to do this. I saw one guy I think on yotatech grind the back of his rims...I do not want to do this.
Will they fit with no mod to the rim?
I know that the dust shield needs it, but rim grinding is a no go.
I'd recommend on not grinding calipers. Nor wheels, for that matter.
Had a caliper go out on me once, on my SC300, after I upgraded to the LS400 brakes.
Not a very fun experience.
The 5 spoke will fit just fine. I have wheels like the one pictured, and I don't have any issues with the calipers or rotors.
Neither a rim or caliper should ever be ground upon. Just asking for part failure.
It's a widely performed practice that if you need a few millimeters of clearance that you take it from the caliper. Anyone taking it from a wheel with anything less than a cnc machine or a lathe is a fool. And we aren't talking a 1/4" or 1/8". That's dumb to take off that much. But a few mm off the top won't hurt anything.
Grind the caliper if necessary but not the wheel.
Horrible advice. There are TONS of people who have tried this and most of them grind into the fluid passage that runs through that area. The ones that don't have weakened it to the point where a failure is more likely.
Don't half ass things like brakes! :wacko:
Oh good grief folks. If you don't feel comfortable doing it then don't do it but don't sit here and give me some sort of public safety message over something myself and countless others have done with success.
I don't feel comfortable with anyone doing it, so I'm going to give you the public safety message every time you suggest this stupid shit. I may be the person you rear end when your half assed brakes let go. Hacking on brake calipers is a stupid idea whether you think you're successful or not.
Exactly
Unless you are a mechanical engineer and have performed analysis, you have no business modifying a critical part like a caliper or rim.
alexaturner
