Tundra CV axles on 3rd gen 4Runner
4wd4runner
I have a 1997 4Runner with a 2.5" lift and my front CV axles have spit out all the grease, so I'm planning on replacing them. I wanted to know Is it possible to directly fit tundra front cv axles on a 3rd gen without any modifications since I know the tundra ones have better joints
Also, what would the part number be or is there any difference between the front cv axles between the different years of the tundra as well as a difference on v6 and v8
The Tundra ones are too long & are only used for Long Travel set ups.
So what are my options? They spit it out because of the angle they are at. I know a diff drop is one but are there any other ones?
do the diff drop, and buy NEW half shafts. I got the ones from NAPA, they were new, not remanufactured and they have a lifetime warranty so if they ever split or break, you can return no questions asked. With only 2.5 inch lift, new CV's and the drop will last you unless you wheel hard on a daily basis.
As others mentioned: Do the diff drop and get new shafts. I went with NAPA on mine and have no regrets. The stock cv's with any kind of miles don't like lifts over 2".
Reboot and use different clamps. Stock ones are prone to leak after you install a lift.
Replacing CV bands - Toyota 120 Platforms Forum
Are the ribs on the boots rubbing against each other? If they are, you can try this:
http://www.toyota-4runner.org/3rd-gen-t4rs/90980-stretch-your-cv-boots.html
You'll still have to remove the shafts to replace the boots. Just put new ones on and rebuild the ones you remove for back-ups.
Personally, depending on how long it has been driven while its been leaking, I would reboot. IMO, I think OEM shafts are far better than NAPA or any other 3rd party with the exception of something like the Lotus or RCV axles. I've rebooted two CV axles and it's honestly not that hard to do. Just wear gloves when working with the grease.
Diff drop would probably be your best option.
I guess you could try using the tundra CV's with the 4runner axles.
Sent from my SM-G900V using Tapatalk
AndiGarage
